Symtoms Of Overheating
Old Jul 12, 2001 | 09:15 PM
MADMAN's Avatar
Here the deal... few weeks my car overheated. the radiator cracked so I order a new and change the thermostat. I let the car idle for a hour to mush sure everything was alright. Now a few days ago Im having the same problem. do anyone have any idea what is wrong? thanks for your help.
Old Jul 12, 2001 | 10:29 PM
AznWontonboy's Avatar
never had the problem. what did you do to cause it to overheat?
Old Jul 12, 2001 | 10:31 PM
vmok's Avatar
Could be a water pump as well. If the water pump is weak, the water won't properly circulate through the system. Did you change the radiator cap? The radiator cap holds pressure to raise the boiling point. When you say that it overheats, is it indicating on the temp gauge that it's running hot? Is the coolant boiling over?
-V
Old Jul 13, 2001 | 07:28 AM
MADMAN's Avatar
vmok
Well the first time the water boil over and crack the radiator. the next time I notice the temp guage was running hot. I did not change the cap. I figure it was still good. The only time this happens is when the car is idling.
Old Jul 13, 2001 | 02:26 PM
sinewave's Avatar
How many miles do you have on the car?
Make sure that both of the fans are operating properly. They are thermostatically controlled, but they should come on as soon as you turn on the a/c.
I would also check the water pump. Remove the radiator cap (cold) and then run the engine until it gets up to operating temp. Once the thermostat opens up, you should be able to see water circulating in the filler neck.
Old Jul 13, 2001 | 05:32 PM
MADMAN's Avatar
Right now Im touching 119000 miles, Im going to try that this weekend and post the results.
Old Jul 13, 2001 | 07:51 PM
dch95's Avatar
Re: vmok
Sounds as if the fan is not coming on to cool the radiator. When you are driving, the wind coming across the radiator is sufficient to cool the radiator. If the water pump was not working, the car would overheat whether you are standing still or driving.
Old Jul 15, 2001 | 01:14 PM
MADMAN's Avatar
Troubleshooting
Well I did some trouble shooting on Sat. The water pump works fine. I thought the fan was okay until the temp gauge started going up so I lift up the hood and notice the fan wasnt running. So i think the relay switch is kaput. can someone confimn this?
Old Jul 15, 2001 | 07:58 PM
sinewave's Avatar
I don't think we can determine what component in the circuit is bad without being there. You really need to get a volt-ohm meter and test each part. I wouldn't jump to any more conclusions; with 119K miles, it could very well be the fan motor.
Old Jul 15, 2001 | 11:38 PM
MADMAN's Avatar
Ill get it check out
Old Jul 16, 2001 | 02:24 PM
dch95's Avatar
Re: Troubleshooting
When you switch on the A/C does the fan kick on then? If so the temperature sensor controling the fan is bad.
Old Jul 16, 2001 | 02:48 PM
sinewave's Avatar
Re: Re: Troubleshooting
Good Idea, why didn't I think of it!?
Old Jul 16, 2001 | 04:57 PM
MADMAN's Avatar
hmmm when i check the fan did not come on. Im going to check again tonight to be sure.
Old Jul 17, 2001 | 02:36 PM
MADMAN's Avatar
fan is not working
Seems to me the problem lies with the fans so im going to have to get them check out.
Miket2006
Mar 1, 2021 03:55 AM
RWCreative
Sep 21, 2015 11:01 AM
97_GXE
20
Sep 17, 2015 08:12 PM
97_GXE
Sep 15, 2015 06:47 AM
