I think my TPS is shot
Old May 10, 2007 | 07:37 PM
maxima985spd
I have a CEL for TPS and 02 07 (which is undefined). Just wondering if the TPS causes the rpms of the motor to fluctuate? no matter what gear I'm in, if I'm like at 2k rpms and step on the gas pedal the rpms shoot up 500 and drop back down to like 2200 while my foot is still on the gas. even happens at WOT
so is that what happens with a bad TPS?
thanks!
Old May 10, 2007 | 09:36 PM
maxima985spd
i guess it's a dead Thursday night...
Old May 10, 2007 | 10:22 PM
ManualMaxima's Avatar
5th Gen till she dies!
yea, mine did that, i did not take it to suck extream as wot, but i would be at idle in gear and my car would go up to 2000 and back down and up and down. least you know your problem so fix it
Old May 10, 2007 | 10:31 PM
maxima985spd
ill try to pick one up tomorrow!!!!!!!!!!!!!!!!
maxima spending all my paychecks on it
Old May 11, 2007 | 05:43 AM
f550maranello2's Avatar
u need to test it first to see if there is a dead spot... then MAKE SURE u adjust the new one that ur getting....
Old May 11, 2007 | 07:54 AM
slinky87's Avatar
but first make sure youre the throttle cable isnt binding or sticking on anything have someonelook at the throttle body to make sure its opening/closing smoothly
Old May 11, 2007 | 08:05 AM
99grnmaxgxe's Avatar
Symptoms of a faulty TPS
Old May 11, 2007 | 09:23 AM
maxima985spd
gey gey gey gey gey thanks guys I don't want to spend 100 bucks on a new one. ill try a junk yard.
Old May 11, 2007 | 12:17 PM
Put up a WTB thread on the Classifieds section, you'd probably get one way cheaper than a new one.
Old May 11, 2007 | 12:32 PM
maxima985spd
im calling every autozone around it's a special order i can get it for 60 bucks there
Old May 11, 2007 | 02:47 PM
Not too bad, just do it soon. Same ish happend to me and I waited so long till it made my tranny slip!
Old May 11, 2007 | 03:22 PM
maxima985spd
oh NOOOOOOOO i hope I havent' gone too long i just noticed the rpms fluctuating within the past two weeks.
Old May 11, 2007 | 06:19 PM
clive's Avatar
100% chingon
Could just as well be the MAF from your description, except for the code! TPS are prone to wear out at one place on the track, because the throttle spends most of its time there. When it gets worn you get fluctuating readings which confuses the computer. A shot of WD-40 into the innards often helps.
Old May 11, 2007 | 09:37 PM
maxima985spd
innards of what? the TPS?
my car runs, starts, and idles fine.
i unbolted the TPS today just so it will be easier to replace.
I didn't really spend too much time adjusting it once I retightend the bolts, but the problem is definitely worse now. i just have to wait to get a new TPS
Old May 12, 2007 | 07:43 AM
Do it quick man, btw is this Aaron?
Old May 12, 2007 | 03:14 PM
maxima985spd
yeeeeeeeeees
Maxboy23
55
May 1, 2025 06:09 PM
James92SE
142
Jan 2, 2024 09:23 AM
Apr 16, 2020 05:15 AM
brichi
Sep 15, 2015 07:20 AM
Stagnet04
Sep 13, 2015 09:32 PM
