99 Serpentine help!
Old May 12, 2007 | 03:48 PM
gixxerjim's Avatar
99 Serpentine help!
Can't tell the proper procedure for replacing the serpentine belt from the half drawing I found in the stickies...little help? Car's on jacks and I am losing daylight!
Thanks!
Old May 12, 2007 | 04:02 PM
CRiME's Avatar
oem ftw!
you can check out the motorvate instructions for alternator replacement, that may assist you in removing the belt:
http://www.motorvate.ca/mvp.php/500
also, there's some information that may help in this thread:
http://forums.maxima.org/showthread....erpentine+belt
good luck w/ the replacement, I know what it's like to be stuck out there working in the dark!
Old May 12, 2007 | 04:54 PM
XJinCT's Avatar
<3's the all motor section
theres just a tensioner if you look by the passenger side engine mount...loosen the nut on the pulley a bit, then get a socket with a long extension on the top part and loosen it up....take off the old belt, but on the new one....be done.
Old May 12, 2007 | 07:18 PM
pmohr's Avatar
No more Maximas...
14mm ratchet wrench, ratchet w/ extension and 14mm socket, and you're done.
Old May 13, 2007 | 08:03 AM
Bobo's Avatar
You might as well replace the power steering belt while you are at it.
If you do that later, you will have to remove the drive belt and install both of them.
Hondarydr
Dec 30, 2024 06:15 PM
homewrecker
Sep 24, 2015 07:01 PM
RWCreative
Sep 21, 2015 11:01 AM
Maxima2010 Prem
Aug 13, 2015 11:34 AM
mdeal
Mar 10, 2008 04:37 AM
