Idler pulley replacement
Old May 12, 2007 | 10:00 PM
whitemax21's Avatar
I need to change my idler pulley. Where is the cheapest place to buy one? Also, when I get ready to remove the belt, do I have to loosen the tension adjuster up top first, or loosen the pulley and then loosen the tension adjuster? I'm kinda confused on the belt. It seems like you would have to first loosen the nut on the pulley before the adjuster would even move. However, in my haynes manual, I think it says to loosen the adjustment on top first??? Thanks.
Old May 12, 2007 | 11:46 PM
pmi3096's Avatar
I had to change mine about six months ago. Super easy. The nissan dealership near me charged around 66 dollars. But i think courtesy nissan has it for cheaper.
Old May 13, 2007 | 05:41 AM
speed racer's Avatar
If your doing it yourself try getting the pulley first b/c lots of times the top nut breaks b/c of rust. The dealership charges $35.00 I think for the pulley. First start off with loosening the bolt on the pulley. Than loosen the top bolt by turning opposite. Righty loosy Lefty Tighty. Its opposite threaded. You should be able to get everything off afterwards.
Old May 13, 2007 | 09:01 AM
whitemax21's Avatar
Thanks for the reply.
Old May 13, 2007 | 09:41 AM
Fr33way™'s Avatar
Wild for Width
Great advice.
Not sure if this was understood but, loosen the bolt on the pulley FIRST and then use the adjusting bolt. If you want to make sure which way you are turning it, pluck the belt (like a rubber band) and listen to the sound. After a few turns on the adjustment bolt the pitch will go higher (tighter) or lower (looser).
lowpost99
Oct 26, 2025 06:53 PM
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
TheMafia
Sep 4, 2015 08:26 AM
