clutch replacement!!
Old May 14, 2007 | 09:18 AM
gunny11218's Avatar
my clutch is slipping bad and me and my friend are going to swap my clutch and id be nice if i knew a few things, how long does it usually take when doing it yourself (he is a certified mechanic though) what will i need, and the biggest thing is will i have to drop my engine? or just my tranny
also what clutch do you guys reccommend.
and any other information that i might need to know feel free to post it!
thanks guys.
Old May 14, 2007 | 09:22 AM
f550maranello2's Avatar
clutch is easy to replace... just takes some work... u just drop the trans which should come out in like a half an hour anyways
Old May 14, 2007 | 09:37 AM
accordingtou's Avatar
VQ30 DE T
Spec stage 1 clutch kit
Is this what your looking for?http://forums.maxima.org/showthread.php?t=521896
Old May 14, 2007 | 03:57 PM
1chewabacha1's Avatar
^^^^LOL^^^^ you just happen to be selling it...?
Old May 14, 2007 | 06:26 PM
KRRZ350's Avatar
Yeah and don't follow the instructions in the haynes or fsm, you don't need to remove the y-pipe or crossmember, instead just remove the 4-bolts for the tranny mount instead of the one tranny mount bolt and it will clear just fine, I never knew that for the longest time until I heard that on the .org, so the next tranny I dropped sure enough it's da truth! If you find a leaking rear-main/upper oil pan seal, you will have to pull the crossmember/y-pipe and upper oil-pan to do it properly.
Old May 14, 2007 | 07:34 PM
tong's Avatar
And if it's slipping, you need to get the flywheel turned. $40 at a local machine shop/parts place. Call around to find out which one does it.
Old May 14, 2007 | 08:38 PM
gunny11218's Avatar
alright guys, so i dont need to drop the huge VQ out of the car?
Old May 14, 2007 | 08:43 PM
for a clutch????
Hell No... just the trans.. its pretty light also... just make sure u get a clutch aligning tool..
Old May 15, 2007 | 07:35 AM
VQ30 DE T
"Every Day I'am Hustling"
LOL.And I just happened to be reading this thread
Old May 15, 2007 | 09:15 AM
gunny11218's Avatar
alright that makes it alot easier on my mind knowing that i dont have to drop my engine, what is the best flywheel and clutch for the money. and how much is a clutch aligning tool?
Old May 15, 2007 | 09:41 AM
KRRZ350's Avatar
You'd actually be suprised, the 'big' vq is actually relatively easy to drop, easier than at least 90% of the cars out there imho, it just looks difficult.
oem 5th gen exedy from nissan is an excellent choice, check the group-deal forum. The clutch aligning tool is only a few bucks from autozone, in fact if you end up getting that maf remind me and I'll drop an extra one that I have in for free.
Old May 15, 2007 | 08:08 PM
gunny11218's Avatar
alright man sounds good. i called the salvage yard today and they want 110 for a used one so im just going to try a few more places so i think you got the deal.
Old May 15, 2007 | 08:12 PM
x91max
does that motor require to be supported when you drop the tranny
CorollaULEV
30
Aug 9, 2021 08:11 PM
dinososexy2.6
Aug 31, 2015 05:37 AM
vanebecker
Aug 17, 2015 08:24 PM
