Pushed the Max to Auto Zone yesterday and...
Old May 15, 2007 | 06:29 AM
LILMAN's Avatar
I guess after months of my CEL being on my car made it clear to me something is wrong with it. After it cut off on me I went to auto zone to get the diagnosis. It came back with P0140(02 sensor) and two P0100 codes one for the MAF sensor and the other for the knock sensor. Is there anything I could try before I spend $300 on new parts?
Old May 15, 2007 | 06:43 AM
f550maranello2's Avatar
put in a resistor for the KS.... and see what happens to the other codes.. they might go away....
Old May 15, 2007 | 06:45 AM
black_maxed95's Avatar
^^^ true
what is it suppose to be...220kohm i think?
Old May 15, 2007 | 06:46 AM
470k ohm..... its 5 for a dollar at radio shack...
slinky87's Avatar
man those codes will pop up on you that dosent mean anything is wrong with the sensors after i did my ground cables and alternator rewire i havent had a problem since the fluctuation of voltage to PCM and sensors will set of the CEL light everytime i also cut the MAF ground wire and mounted a new ground right next to the strut tower and havent had any problem since
...ya i just searched and was about to edit my post
Old May 15, 2007 | 06:49 AM
NmexMAX's Avatar
dot dot dot ...
Who said it would be 300$ for parts?
Old May 15, 2007 | 06:53 AM
sensors are about a hundred a crack and he has codes for 3 of em
Old May 15, 2007 | 07:00 AM
NmexMAX's Avatar
dot dot dot ...
MAF = 45
O2 = 75
KS = 65-90
210, worst case scenario.
But, the KS is oftentimes triggered by the O2. So, change the O2 sensor, and the KS might go away.
Old May 15, 2007 | 07:09 AM
(i round up the the nearest hundred, lol)
anyways...
to help out LILMAN, i know there is a way to test the knock sensor with an ohmeter, not exactly sure how to though. Can the other sensors be tested in a similar manner (i woud assume so)?
Old May 15, 2007 | 07:21 AM
NmexMAX's Avatar
dot dot dot ...
I think a Haynes or Chilton Manual is a good investment.
Checking MAF sensor:
http://forums.maxima.org/showpost.ph...4&postcount=15
Old May 15, 2007 | 07:40 AM
LILMAN's Avatar
Originally Posted by NmexMAX
MAF = 45
O2 = 75
KS = 65-90
$210!?! Where do you get your parts from?
I'll check the voltage, and go from there. Good lookin out.
BTW Whats the part number for O2 2 Bank 1?
Old May 15, 2007 | 07:49 AM
slinky87's Avatar
test? ok test your knock sensor but you cant test it under load unless your on a dyno so thats out the question bad 02 sensor yea maybe but i dont see how that would set off MAF and knock codes from what i was syaing earlier try the Alternator rewire and ground mod then cut your MAF ground and make a seperate ground for close as possible i had the exact same 3 codes come on but since those mods no problems
Old May 15, 2007 | 08:42 AM
ewuzh's Avatar
MAF: org classifieds or junkyard
knock: ebay $65 shipped, brand new nissan oem
O2: automedicsupply
captchaos
Mar 15, 2016 12:18 PM
Maxboy23
Sep 9, 2015 10:37 AM
robtroxel
Sep 8, 2015 08:15 PM
MaxLife17
Sep 8, 2015 02:36 PM
nbstriker10
Sep 4, 2015 04:26 PM
