Another CEL light, HELP!
Old May 16, 2007 | 04:20 PM
Graem's Avatar
I just checked myu ECU and i had 4 codes pop up. 0705 and 0903 are both EVAP codes but i have no idea why they are coming up and how to fix them. I reset my ecu and they poped up again after 5 min. I am also throwing a knock sensor code as well as a 1050.
What should I do? How serious are these codes? What can i do to fix them?
Please HELP
Old May 16, 2007 | 04:35 PM
99BlackMaxMS's Avatar
Read the stickies, post a description of the codes and then post back here...or phenryiv1 will lock this
Old May 16, 2007 | 06:22 PM
gen4maxima536's Avatar
work on that 0903 first, it may be as simple as replacing that valve on the charcoal canister.
the 0705 looks more like a jackpot code, and doesn't really tell you a whole lot.
0304, the knock sensor code, just get a new knock sensor
and i didn't see 1050 in the sticky, so you should pull your codes again and make sure thats right.
Old May 17, 2007 | 09:02 AM
maximafrenzy's Avatar
Fuhget About It.....
The cheapest 1st step for evap codes is the gas cap, then get your fuel pressure checked, Ive had those codes it turned out I had a fuel pressure leak in my gas tank filler neck. Secondly I think you meant 0150 not 1050; that is the 02 sensor on your y pipe, its the front left one at the front of the pipe.
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
ballerchris510
Sep 10, 2015 09:35 PM
-ReLLiK-
Sep 8, 2015 12:02 PM
A32goldylocks
Sep 2, 2015 06:39 AM
