Factory alarm beep help!
Old May 18, 2007 | 02:38 PM
kkskkskks's Avatar
Hi all, I followed the write in vqpower about installing a buzzer for beep sound when you lock the doors, it was working great but not loud enough, so I brought a horn trying to hook it up, however the horn doesn't sound, so I remove it, then something goes wrong: when I keylessly lock the doors the hazard light doesn't flash, there is a constant non-pulsing beep sound near the driver side fuse box. I checked both fuse boxes in the engine bay and driver side but don't see a blow. When I plug the hazard fuse out the beep stops but the hazard still won't flash, does any one know how to solve this? I think this is related to hazard lamp wire and body control module, please help thanks.
Old May 18, 2007 | 09:55 PM
Majestic's Avatar
Yahhhhhhh
hmmm. sounds like you blew a fuse but you said you checked them all? how about the security fuse? I would replace it anyways.
Old May 19, 2007 | 03:11 AM
kkskkskks's Avatar
is there another fuse box beside the one next to the battery and the one under the steeling wheel?
Old May 19, 2007 | 07:27 AM
maximabebe's Avatar
I would take out all the new parts, relays, buzzer and everything. Staer from scratch with new parts but this time put the piezo buzzer through the trunk and mount it up in the rear bumper. Make sure its secure and doesn't get wet. Should be loud enough for ya.
Old May 19, 2007 | 09:48 AM
TSoprano's Avatar
You may have blown the flasher module.. Search "alarm beep" in 4th gen forums for more info on your flasher problem.
No need for all that stuff in the vq writeup anyway.. The RS buzzer from the writeup works great if you mount it outside the car.. There's a plug back there to run the wires out and mount the buzzer under the back bumper. (spare tire well drain plug maybe i can't remember).. Splice into the wires off the bcm relay back there. I don't remember the wiring off hand.. Hit the arm button on yer fob and check em with a multimeter. I think it was red-orange and black to one of the green/oranges or vice versa. Mount buzzer to the bumper Styrofoam and your good to go..
Old May 19, 2007 | 10:17 AM
Cdg2125's Avatar
You need to make sure the fuses are not blown. Did you take each fuse out or what? You most have not gotten a good buzzer cause I can hear mine 20-25ft away from the car. What is this horn thing you installed? If the horn needs more power you probably blew fuses. They wouldn't just stop flashing. You probably wouldn't have blown the alarm box and you're blinkers do work correct? It has to be a fuse.
Old May 19, 2007 | 11:08 AM
kkskkskks's Avatar
I checked each fuse in those two boxes, but none was blown. My turning and hazard light still works. does anyone know where the flasher module is located? I took everything I installed out but it still not flashing when I lock the car. btw, when would there be a constant non pulsing beep sound going on related to the hazard light? since when I take the hazard light fuse off it stops the beep.
Old May 19, 2007 | 01:05 PM
Cdg2125's Avatar
If the buzzer keeps buzzing nonstop you wired it incorrectly. The box is in the trunk behind the carpet on the right side.
Old May 19, 2007 | 05:43 PM
BlkMaxNCa's Avatar
Yeah double check the box on the right hand side of the max in ur trunk, make sure the cord is plugged in and all hooked up.....I can hear myne fron about the same length 20-25 feet away, shoot mine is loud
Old May 20, 2007 | 11:03 PM
kkskkskks's Avatar
I checked the box on the right side of the trunk, they are all plugged in and hooked up, I haven't change anything but the bcm unit so they wouldn't be unplugged. Is the security fuse located together with other fuses? since I couldn't find a fuse says security. I definitely sure it's about the hazard circuit but don't know where it gets wrong...
Old May 21, 2007 | 02:29 PM
kkskkskks's Avatar
does anyone know how to reset the bcm unit?
Old May 21, 2007 | 09:12 PM
kkskkskks's Avatar
i notice something abnormal today, that the security led is blinking faster than it used to be, any thought?
Old May 23, 2007 | 12:18 AM
kkskkskks's Avatar
would it help if i replace the bcm unit under the center console?
my03maxima
Jul 28, 2024 07:40 AM
chisam14
Nov 6, 2018 08:56 PM
magiconthetire
Oct 26, 2015 09:03 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
