I can't find my f888ing egr guide tube.
Old May 19, 2007 | 12:44 AM
Eric425's Avatar
Removing my upper intake manifold. I can't find my egr guide tube to disconnect. Where the hell is it? Is it hidden from view, right under the iac?
Old May 19, 2007 | 06:04 AM
speed racer's Avatar
it attaches right onto the upper intake manifold. Its on the right hand side next to the IACV. I think its a 12mm bolt. Also, if your removing the UIM make sure you have some needle nose plyers to take the clamps off the coolant hose.
Old May 19, 2007 | 01:48 PM
maxima985spd
it has two connections. one right next to the starter and the other is on the upper intake manifold on the back right. PM me your email address so i can send you a write up on how to remove it.
Old May 19, 2007 | 02:10 PM
gatorsteeler's Avatar
yea...i figured this out first hand as well when i removed intake and throttle body to clean both the TB and the tubes in EGR...i gave up on the EGR for now cuz i cant get my long *** frame n there to squeeze them bolts off that are hidden (of course)...i like when they hide stuff in cars...especially when its almost certain to fail
Old May 19, 2007 | 03:14 PM
Eric425's Avatar
I don't even really know what an egr guide tube is. I know what an egr is, but not a guide tube. this is really pissing me off. I found something that kinda looks like it in the pic. It looks like it connects to the manifold and is located under the iac. But I can't find the bolts to unattach the bracket in the manual. I found something that looks like an electrical wire that connects an octagonal metal thing on the manifold on one end, and to an electrical plug connector on a tab by the iac on the other, that plugs into another plug. is that it?
Old May 19, 2007 | 04:34 PM
maxima985spd
to clean it you will have to remove a part that is right next to the egr guide tube it looks like a squiggly metal pipe it's about 8 inches long
Old May 19, 2007 | 07:32 PM
Eric425's Avatar
Got the bolts, thanks to everyone. I don't need to remove it to clean, I just need it unattached to the manifold so i can get the damn manifold off. it seems rusted on pretty good... should I just pry it off? Do I need to disconnect some PCV tube... the haynes manual doesnt say anything about that? Come on... i know a bunch of you guys have done the mevi so you know how to remove an intake?
Old May 20, 2007 | 05:00 AM
natty99's Avatar
http://forums.maxima.org/showthread.php?t=496494
kjlouis
Oct 3, 2015 05:29 AM
Vistance
Sep 17, 2015 05:17 AM
adamgalazka
Sep 8, 2015 01:27 PM
