besides 300zx...any other bigger brake conversion for Max?
Old May 19, 2007 | 02:17 PM
gatorsteeler's Avatar
Plain and simple after driving this car for a month- i dont like the brakes, dealer had new pads on good fluid levels and it still stops like doodoo.. im assuming the brakes they put on my Max are just not sufficient for a 3000lb+ car. anybody know where i can find a write up on this?? a website? mainly my question would be do new 350Z brakes convert over bcuz im eventually gettin same Z rims. if i cant find out here i'll just go bother some grease monkeys over @ Nissan ...thanks
Old May 19, 2007 | 02:20 PM
Kevlo911's Avatar
Kevlo for President
J/Q45 calipers are used in some BBK's. You can search for Maxima big brake kits and find some that fit but they are quite expensive. Ksport also has a kit
Old May 19, 2007 | 02:41 PM
NmexMAX's Avatar
dot dot dot ...
How much are you willing to spend?
http://forums.maxima.org/forumdispla...sprune=-1&f=87
Old May 19, 2007 | 03:18 PM
Nealoc187's Avatar
SLOW
Virtually any brake could be made to work with the proper brackets and lines...
But unless you are into racing or really really want the BBK "look" it sounds to me like you just need some pads that don't suck.
Old May 19, 2007 | 08:04 PM
LudaTej's Avatar
if 300zx brake kits work get some brembo cross drilled and slotted rotors
Old May 19, 2007 | 10:54 PM
Zack342's Avatar
you can use Q45 calipers and 300ZX rotors which have to be milled down 2-3mm.
you can use 300ZX calipers and 300ZX rotors which have to be milled down 2-3mm
you can use Q45 calipers and ford mustang cobra rotors will jeff92se's brackets and hubcentric rings
you can use 300ZX calipers and ford mustang cobra rotors will jeff92se's brackets and hubcentric rings
Old May 19, 2007 | 11:19 PM
i've already checked on the ultra reliable brembo set...for all corners-$2500 for the site i was at....GOOD LAWD THATS A LOT OF MONEY!!! the thing is, i've got an auto and obviously i dont drive this car to race (just to get azz) so i just need something that is going to be bigger and less likely to pizz me off when im grinding on rotors prematurely. having rotors milled is not a big deal, im sure i can go to a machining shop and give someone $10 to do it.
Old May 19, 2007 | 11:24 PM
yeah, i noticed that my front rotors had slight grooves in them which gave me the impression that either the previous owner was careless or that the car had continous brake issues and he traded it in. the dealer most likely threw some flea market quality pads on to sell it to me-a dumbass j/k.......
Old May 19, 2007 | 11:26 PM
i'm guessing that q45 are same size calipers as 300zx??
Old May 20, 2007 | 05:35 AM
4DRSpeed's Avatar
Project Ruby......
im sorry. sitting here at work that just made me crack up. gotta count on the car to get the booty call.
Old May 20, 2007 | 06:57 AM
nightspyder0's Avatar
just get some hawk pads, new rotors and some stainless steel brake lines.
Old May 20, 2007 | 07:12 AM
Nealoc187's Avatar
SLOW
no, q45 calipers are the same as j30 calipers.
Old May 20, 2007 | 06:19 PM
Cdg2125's Avatar
what size rims do you have? If you don't have 18's you won't fit any setups. Well that's not true. The 02 17's do fit some. Also not mentioned was the 6th gen brakes. They also will fit as a bbk.
BTW: Isn't this already in the stickies?
Old May 20, 2007 | 07:12 PM
huyqvu's Avatar
at first i did slotted rotors, ss lines, and oem pads. worked ok. needed new pads so i went with hawks and they work so much better.
Old May 21, 2007 | 09:15 AM
JtzMax's Avatar
Whatchyou say?
I like Brembro pads ... that is what I run and they work great. I want to upgrade to sloted and drilled rotors, but have other things to do first.
Good to know that you need larger rims to fit larger brakes, only makes sense. Cheers!
Old May 21, 2007 | 10:16 AM
phenryiv1's Avatar
Mod her. Ate her.
http://forums.maxima.org/showpost.ph...1&postcount=13
Does ANYONE read the stickys?
captchaos
Mar 15, 2016 12:18 PM
bbsitum
Sep 11, 2015 04:55 PM
jcvgn
Sep 10, 2015 08:03 PM
Hdnseek
Sep 9, 2015 05:55 AM
Maxboy23
Sep 4, 2015 06:04 PM
