Long cranking times when engine warm..
97 SE, 99k miles. When engine is warm/hot sometimes it takes up to 5 full seconds of cranking to get the engine to fire. When the engine is cold it fires within usually 1 second of cranking. This occurs ONLY when the engine is warm/hot. It is more obvious when the engine has had an hour or two to cool a bit, but still way above a cold start environment.
I've replaced:
thermostat
ECTS
reset the PCM (battery cable off for 12 hrs)
throttle body cleaned
cleaned the AIC
I'd appreciate any thoughts on this one. It has plagued the car since shortly after the 3/36 expired in late 2000.
thanks
I've replaced:
thermostat
ECTS
cleaned the AIC
thanks
It sounds like the ECTS. Which brand did you use? 'Cause i went with GPSorrensen first, and that cured the warm hard-starting issue, but made my rad fans spin @ 100% all the time. After putting in an OEM nissan ECTS, everyhting is fine
I replaced it with I think it was a Wells brand or such. It's been probably 4 years ago now. I'll check on the OEM one. Can't ever recall it happening when the engine was cold (more than say 6-8 hours.)
kjlouis
Nov 24, 2018 06:09 AM
conansriver
Sep 3, 2015 06:38 AM
max_speed97
Aug 26, 2015 07:46 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
