What year ECU to use after 5spd conversion
Old May 23, 2007 | 12:23 AM
ukraini9mofo's Avatar
I had my car conevrted to 5spd for over a year now and I am tired of CEL illuminated at all times as well as RPMs stayin at 1.3 RPMS until I come to a dead stop then they drop to normal. Since my car is a 99 I am thinking that if i get 99 5spd ECU then since 99 have immobilizer it is not goin to start, mb i sohuld get 98 ECU?
Any input will be appreciated
Old May 23, 2007 | 12:46 AM
VIP Maxima
get a ecu for 5spd 99. u need to pay attention to FED or CA spec too. if not the proper year, the there will be a CEL, specially with 99 being the last year.
how is everything else running besides the CEL ?
www.car-parts.com
Old May 23, 2007 | 12:59 AM
www.car-parts.com
knock on wood everything is good, but am i not going to have problem with immobilzer since there is a chip in 99
Old May 23, 2007 | 04:27 AM
WielkiWaac's Avatar
MaximaDriver
you will have to go to nissan dealer to get your key programmed.
btw have a good time with P1706, i just cant get rid of that thing after 5spd swap
Old May 23, 2007 | 05:30 AM
MaximaSE96's Avatar
Maxima Owner
its always best to use the same year car if possible
Old May 23, 2007 | 06:00 PM
any1 rties using 98 on 99?
Old May 23, 2007 | 07:36 PM
WielkiWaac's Avatar
MaximaDriver
i think it is possible but you will get CEL
Old May 23, 2007 | 08:06 PM
OnEBadAsSi30's Avatar
I took out the CEL Light. I just run a full diagnostic test at school every week or so to make sure everythings still working right with the Snap On Modus. I'm still running the auto ECU. I do plan to swap soon to at least an manual ECU. Also you can take your Automatic Tranny computer and get rid of 5 codes I believe for the shift solenoids and for the Torque Converter. Its right behind the Shifter underneath the radio. Its about the size of your fist and use a 10mm to take it off.
Old May 23, 2007 | 09:53 PM
Blackwind's Avatar
i may have that problem solved stay tuned for details.
Old May 23, 2007 | 10:15 PM
darklegend06's Avatar
sweet some one might be able to solve the p1706(1003) code soon!!
Old May 24, 2007 | 04:46 PM
HEY anyone running 98 ECU on 99 because I might try that as after I removed the Automatic Trans Computer I get 2 codes for not all harnesses being plugged in
QueensMAX
Sep 15, 2015 04:14 AM
lux97Max
Sep 11, 2015 01:12 PM
ef9
Buyer/Seller Feedback
Sep 10, 2015 10:13 PM
ballerchris510
Sep 10, 2015 09:35 PM
Hdnseek
Sep 9, 2015 05:55 AM
