Need Knoc Sensor Change, South Bay Area, CA Willing to pay
Old May 23, 2007 | 10:51 AM
nitink's Avatar
I had posted in local forum but no use, hoping someone here could help me out.
My 95 Maxima is throwing the knock sensor code and it needs to be replaced.
If anybody in South Bay Area, CA has previous experience (sucessfully) & tools for replacing the knock sensor on a 4th gen max then I will pay you up to $20 to install it for me.
I have sensor with me.
Old May 23, 2007 | 12:11 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
http://forums.maxima.org/showthread.php?t=521816
What do you mean you had no use posting it in the local section? Looks like someone responded.
Old May 23, 2007 | 12:18 PM
99grnmaxgxe's Avatar
Didn't a thread just like this get locked yesterday?
Old May 23, 2007 | 01:07 PM
OnEBadAsSi30's Avatar
The knock sensor doesn't throw a code. Check the harness that goes to the knock sensor. That's what throws the code.
Old May 23, 2007 | 01:12 PM
Cdg2125's Avatar
I'm assuming this will get locked, but you should check the wire as previously stated. A lot of the time the wire is the problem not the sensor. Why not spend less than $20 on tools and fix the thing yourself?
Old May 23, 2007 | 05:09 PM
nitink's Avatar
Thanks everyone I will check the wires.
Turbo Max's Shop is in San Bruno, about 50miles away, I will prefer not to drive 100 miles (to & fro) for knoc sensor change.
Old May 23, 2007 | 05:39 PM
th0ught's Avatar
^ Wow you're in Campbell and you're thinking about driving to Matt's shop? Matt's shop is great, but definitely not worth the trip for a KS, I don't blame you for willing to pay $20 (basically the cost of gas).
Old May 23, 2007 | 07:35 PM
NmexMAX's Avatar
dot dot dot ...
This statement is incorrect.
The knock sensor will toss a code even if the harness is good. Keep in mind, throwing a code and setting off a CEL are not the same thing.
Old May 25, 2007 | 11:31 AM
Max Noob's Avatar
id help you out.but im so cal.
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Oct 27, 2015 01:29 PM
maxinout93
Aug 20, 2015 02:17 AM
ViciousVQ30
Aug 5, 2015 05:40 PM
RealityCheck
Aug 5, 2015 06:18 AM
