Engine Service Light came on
Old May 23, 2007 | 03:17 PM
x X CLoud X x's Avatar
the car is a 97 5speed w/ 95,000 miles, and the Yellow Engine Service light just came on, what replacements should i do, in order to fix this problem?
Old May 23, 2007 | 03:18 PM
97SEdriver's Avatar
this place is dead
um...pull the codes?
Or just replace the engine.............
Old May 23, 2007 | 03:31 PM
pmohr's Avatar
No more Maximas...
Easiest and most cost efficient way to reset the CEL. Your battery will be disconnected long enough during the swap to make the CEL go away...just keep a couple spare engines as the CEL will probably come back on eventually.
Old May 23, 2007 | 04:29 PM
Neo Raven456's Avatar
with 200+ posts and a question like that, you probably deserved the responses you just got XD
I'd leave some sort of comment, but I feel like helping you out. Take a screw driver, turn the car to ON, pop off a panel near the gas pedal, turn the screw all the way clockwise, wait 5 seconds, turn it all the way counter-clockwise, look at the SES light, it will blink two series of numbers, a series that blinks long and slow and one that is short and fast. Add these numbers together, i.e. "blllliiiinnnnnkkkk (long/slow) bllllllliiiiinnnnkkkk bliiiinnnkkkkkkkkk blink(Short/Fast) blink blink blink" would be 0304. Once you have these numbers, look online or in a book to identify what the code means. Then fix it. The end
Old May 23, 2007 | 06:43 PM
i just fixed the problem today, and it only took me 2mins
anyone know of a cheap site/place for an alternator?
Old May 23, 2007 | 07:13 PM
96DentKING's Avatar
Old May 23, 2007 | 07:21 PM
NmexMAX's Avatar
dot dot dot ...
So what was the problem? As far as alternators go, I got mine @ AutoZone.
But, from the lack of information of your post, it's difficult to decipher what's really going on.
A.) You stated you fixed i, but did not state what was wrong.
B.) You asked about an alternator. My assumption is, you think the light turned on b/ of the alternator, in which case, you would be incorrect, the CEL does not light up when the alt. is dead/dying. The battery light and/or brake light will light in the event the alt is bad.
Old May 23, 2007 | 08:57 PM
andrei3333's Avatar
this thread is useless, the OP has no information to provide. Buddy where have u been since u joined in January of 2005 ?
who has 200+ posts and then creates this thread, i feel so cheated because i had to read the FIRST post and almost threw up inside a little...this is awful
Old May 24, 2007 | 05:31 AM
3 point slow's Avatar
^^^^^ LMMFAO!!!!
I hate to bump this up again but that just made my fkn morning.
Old May 24, 2007 | 08:12 AM
TurTLe*'s Avatar
what he said i'm on the same boat. ALT has NOTHING to do with check engine lights. i had a completely dead alt. and it was running just off the battery. enought to start it enough to not let the battery light turn on cause it was over 12 volts like 12.3v and never a check engine light.
none of us are god. If you need some help first step is go to to autozone. and get it scanned and write down the Pxxxx number and maybe what it has to do with. say o2 sensor or knock sensor. seems very common on our POS's. while your there get a quote for your alternator. come back home post it up and we tell you what we think. you go back buy your altnetor if needed and items to cure light
Old May 24, 2007 | 11:01 AM
VIP Maxima
READ THE STICKIES ! READ THE STICKIES ! READ THE STICKIES !
Old May 24, 2007 | 11:21 AM
f550maranello2's Avatar
my cats breath smells like cat food
99BlackMaxMS's Avatar
....seriously dude get with it
NOW PLEASE
Old May 24, 2007 | 01:05 PM
Digitized's Avatar
hahaha
LMAO
Ralph rulez!
Old Jun 18, 2007 | 10:33 AM
Big EEEE's Avatar
Did you read the STICKIES...make sense?
Old Jun 18, 2007 | 11:22 AM
WhiteA32's Avatar
Go to autozone/napa and have them check your codes....
Old Jun 18, 2007 | 04:52 PM
Mobscene's Avatar
Why the hell would you dig this up.
vingodine
45
May 21, 2016 12:46 PM
rbaker100
Aug 28, 2015 08:11 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Flores94
Aug 11, 2015 12:53 PM
