cost of these parts?
Old May 23, 2007 | 05:43 PM
max2moon17
i just took my car for inspection, and i asked the guy how much is everything going to cost and he said it won't be cheap! im guessing that its going to be alot of $$$$$. then i asked him what needs to be replaced and he said: rear brake rotors, rear brakes, and left front housing. what do you guys think about this. im worried.
Old May 23, 2007 | 05:58 PM
mge2790's Avatar
not sure how mechanilcally inclined you are, but replacing brake rotors and brake pads is easy enough, might want to consider doing it yourself not sure about the housing
Old May 23, 2007 | 06:00 PM
th0ught's Avatar
The parts shouldn't cost "alot of $$$$$", sounds like the guy is either exaggerating or trying to make a buck off of you. Rear rotors would be around $70 plus shipping (depending on brand, I'd suggest Brembo blanks) and rear brake pads $30-60 (depending on brand). Both could be sourced through the Group Deal forum at good prices. Labor for a brake job for the rear (swapping out rotors and pads) shouldn't exceed $50.
Old May 23, 2007 | 06:12 PM
max2moon17
thanks alot i was thinking it was cheap, but i wanted to ask you guys first. and what about the housing?
Old May 23, 2007 | 06:13 PM
CaptainFill's Avatar
Drop it off at my house and ill fix it all for 100 bucks + parts But seriously... do it yourself. Its not hard, not too time consuming and you will know the job was done well. With the few hundred bucks you saved go out for a nice... really nice dinner or something
Old May 23, 2007 | 06:15 PM
gen4maxima536's Avatar
what do you mean by left front housing?
Old May 23, 2007 | 06:21 PM
max2moon17
the mechanic just said i need a new left front housing. i have no idea what he meant, i was so nervous that i 4got to ask him what the hell is a left front housing.lol
Old May 23, 2007 | 06:25 PM
usually i'd say "housing" is associated with things like headlight housing, fog light housing.
guess you'll have to call him up and figure out what he was talking about
Old May 23, 2007 | 06:27 PM
max2moon17
oh i think it is the left fog light......bcuz i now remember that it had a crack, im so stupid.....you are the best "GEN4MAXIMA536" thanks alot... if this was nycmaximas.org i would of gave you some rep points...lol...thanks again.
Old May 23, 2007 | 06:31 PM
np
looks like you'll be watching the 4th gen FS forum like a hawk for a fog light then, like many of us
and the fog lights are held in by a screw or two from the outside = easy fix
Old May 23, 2007 | 06:34 PM
max ride 41's Avatar
except for the fact that most mechanics charge around 70.00 an hour for labor, and unless your a friend of the tech in question, i would say minimum of a 100.00 for labor. and the parts should be around 200.00, unless you want to buy online at an aftermarket site.
Old May 23, 2007 | 06:40 PM
max2moon17
i have one last question for you guys, can i still pass inspection/emmisions, if i don't do those things right now?
Old May 23, 2007 | 06:47 PM
now stop and think about that for a minute, the brakes are probably pretty messed up for him to say you need them. and no, it won't pass insp. with bad brakes and exhaust unless your mechanic lets slide and do them later, which i doubt. he could lose his license by doing that.
th0ught's Avatar
I forgot that was so and that's true depending on where you're from. Here in the Bay (as long as you stay away from Stealerships) shops charge based on the specific job not by the hour, friend or no friend.
TurTLe*'s Avatar
yes you will pass. fogs lights are aux lights. they dont have anything to do with inspections it should only be headlights. brakes do nothing with emissions. Only thing is MAYBE if they do safety inspection they might note your brakes but i never heard of such thing nor do i live in a state that inspects your car.
rear brakes are something that can be taught to a girlfriend in a matter of minutes. i've showned my girl how to do it on my max and she is ready to do it on her lancer. all she needs is my tools and for me to take the wheels and jack up the car. she isn't the best at that but she can do it. so i mean there are write ups. hell any write up should do cause brakes are brakes.
first timers 4-6 hours at most. me personally 1 hour at most cause i tend to get carried away with music and drinking.
Old May 23, 2007 | 06:57 PM
max2moon17
thanks guys
Old May 23, 2007 | 11:19 PM
95 Maxnout's Avatar
Hey Chris,If you want a 2nd opinion check out Kanns auto repair in willow st.(717)464-2550.Thats where we get our cars worked on.Very dependable and fairly priced.
Old May 24, 2007 | 12:13 AM
MaximaSpd85's Avatar
i would say do the brakes definitely...the fogs i wouldnt worry about because if you REALLY need to get it inspected and u need new fogs, u can just take them off(??) and the inspector will never know u even had them. Brakes can be bought for as low as around $25 at a local auto parts store. Depending on the rotors and their condition, u may even get them turned for less than that but it is a good thing to have brand new ones.
Old May 24, 2007 | 07:49 AM
TurTLe*'s Avatar
if your doing it at home. its faster and easier to buy the rotors. because in order to get them cut you would need a 2nd car and to run to either a shop or a store to cut them for $5-10. VS cheapest rotors are 15$-25$ and thats saves you 1 hour worth of traveling back and fourth and dirtying other cars.
I dont recommend you go extremely cheap on brakes but it is your rears that only do 20% or so. And you probaly never need to replace them again. its normally 2 sets of the front per 1 in the rear. Without knowing what you would like to spend and what your driving habits are. I cant really give a accurate recommendation. But i personally think Hawks HPS pads are the best "bang for the BUCK" @ 40-60$ a set of front or rears. They stop great and low dust. its more about the pad then the rotor tho.
Old May 24, 2007 | 08:16 AM
Suzie (v)Q's Avatar
Fast & Furry-ous
www.rockauto.com
5% Discount - enter "670787605023" in the "How Did You Here About Us?" box. Good through July 24, '7.
___
JLD
Old May 24, 2007 | 10:44 AM
DomoMaxima98's Avatar
Get the brakes done, take the fogs off and put them back on AFTER inspection.. i got caught up liek that when i had a Galant and they wanted 200 dollars for fogs on a 95 galant.. GTFOH..
get the brakes done and take off the lights
MR2 T'd
Jul 9, 2021 05:06 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
JoshG
Sep 5, 2015 10:10 PM
