Just done springs, have questions..
Old May 24, 2007 | 05:22 AM
jordandalley's Avatar
Hi All,
I recently installed new aftermarket springs in my Max. On the front two springs I forgot to put that foamy spring covering on the bottom of the spring from the old stock ones. The springs just sit directly on the strut seating. When I turn when stationery, i sometimes here the springs shifting on the strut seating. I'm just wondering if I should maybe compress them and put the seating back on again. My concern is the springs may be grinding away at the strut seating.. any ideas guys?
Cheers.
Old May 24, 2007 | 06:07 AM
pmohr's Avatar
No more Maximas...
They won't really grind away at the spring perch, the isolators just prevent all that noise from occurring.
Old May 24, 2007 | 09:10 AM
sublimeskunk's Avatar
that happened to me once, it wont stop clicking until you re-seat the spring correctly.
Old May 24, 2007 | 11:32 AM
ProjectMax96's Avatar
ya, mine make noises like that also. I have driven for almost a year like that with no problem accept your car sounds like **** when you make tight turns
Old May 24, 2007 | 11:35 AM
95turbo gxe's Avatar
yep mine was noise as hell till I reseated them back in .
Old May 24, 2007 | 04:24 PM
yeah, looks like its a common prob. Problem is i threw out the isolators. Cheers to pmohr for the correct term for those spongie things - isolators. I'm sure my local suspension shop will have some. Theyre probably a generic thing.
Cheers for the responses guys
Old May 24, 2007 | 04:54 PM
RA030726's Avatar
I'm nutty for Nissans
if the spring is binding the strut bearing is worn out and needs to be regreased or replaced.
Old May 24, 2007 | 08:56 PM
ThurzNite's Avatar
Another vote for strut bearing.
Jae
Old May 25, 2007 | 05:20 AM
phenryiv1's Avatar
Mod her. Ate her.
OR
Most likely you don't have ther springs clocked correctly or the bearings are worn out. These, more than not having isolators, are your likely culprits.
You can make new isolators with cable wrap from Radio Shack, but it is not as good as OEM wrap.
Old May 25, 2007 | 06:22 AM
cheers guys. i'll check that out
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
MaxiNoob98
Oct 2, 2015 10:13 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
followthadollar
Sep 27, 2015 01:06 PM
