help idle drops causing shake
Old May 28, 2007 | 01:07 AM
zarek66's Avatar
i need help when i'm at a stop light and the car is idling, the idle would drop rom 750 and dip down to 500 and than back up to 750 for 5 seconds than drop again. When i start to drive off than it's fine but only happen when i'm idling in gear . it's an auto btw. i'm thinking ignition coil but don't know how to use an ohm meter, to check the ignition coil. any suggestions as to what it might be? please help
Old May 28, 2007 | 04:31 AM
jordandalley's Avatar
Check your IACV. Mine fluctuates a lot when the IACV is set too low. Adjust it with a screwdriver and see if this changes it. Might just be starving for air at idle in gear when the AC comes on and off.
Old May 28, 2007 | 05:09 AM
matty's Avatar
Take some time and clean the TB and IACV as well. That will make a huge difference in how the car will idle
-matt
TKHanson
Nov 24, 2018 01:39 AM
Unclejunebug
Apr 2, 2016 05:42 AM
maxima-junky
Oct 7, 2015 06:13 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
