Flashing Ces
Old May 30, 2007 | 04:09 AM
Maximeyez's Avatar
Flashing Ces
Has anyone else had this happen. If I nail the gas the car hesitates around 4000 rpm and the CES light starts to flash and continues to flash for a few seconds. The car hesitates and just has no power. I tried changing the fuel filter, just had the plugs replaced, and just had all the injectors flushed and cleaned. Can anyone think of what the hell is going on?
Old May 30, 2007 | 05:06 AM
99BlackMaxMS's Avatar
Your car is misfiring badly. Change the coilpacks.
Old May 30, 2007 | 05:24 AM
heynow's Avatar
Old May 30, 2007 | 06:27 AM
NmexMAX's Avatar
dot dot dot ...
For clarification, it's SES, not CES. You may have confused it w/ CEL
SES = Service Engine Soon
CEL = Check Engine Light
Universal term, MIL = Malfunction Indicator Lamp.
Blinking/flashing SES light is typically indicative of a multi cylinder misfire.
Old Mar 24, 2011 | 09:06 PM
Kenneth Joseph's Avatar
I had the same problem. Car was losing power and hesitating approximately a week after I had the oil seals on the manual trans replaced. Then the MIL began flashing at high speeds. After a close check, it turned out to be an intake air leak. One of the clamps which holds the MAF air ducts to the main air intake was loose. I hope this helps.
Old Mar 25, 2011 | 07:13 AM
cashoit's Avatar
I have a SRI. Periodically, I will go and tighten all the clamps for it. They always a lil backed off whenever i check it.
OP,
sounds like your coil packs are on they last legs.
Old Mar 25, 2011 | 07:26 AM
K-Ryder's Avatar
Check your intake make sure its not loose, Check your coilpacks for power if you have a test light it will help you or if you dont use a screwdriver with a clear handle, also check your spark plugs again, if you see oil on them, then you'll have to take off the valve cover and replace the seals on the spark plug cylinders.And also change your valve cover gasket.
But before you do any of that first go to AutoZone have them check the ECU to see what codes are pulling up. Come back and post the code. From there we can determine whats you should do.
bryants95max
Oct 2, 2015 12:52 PM
dshinn
Sep 26, 2015 08:07 PM
Colossus
Sep 9, 2015 05:46 AM
intimidator
Sep 5, 2015 07:23 PM
Team STILLEN
Aug 10, 2015 04:29 PM
