oovi OR MEVI can not decide
Old May 30, 2007 | 05:46 PM
TysMadmax's Avatar
Well I am just wanting some info on which to get I know that the mevi is basically bolt on and the oovi is a lot more envolved. But what is the best setup if later I want to go supercharged?
Old May 30, 2007 | 05:53 PM
NmexMAX's Avatar
dot dot dot ...
If you plan on supercharging, either one is good.
If you plan on getting the most out of your set-up, S/C or N/A, 00vi.
If you posted this question at this date and time, you have not seen the advanced performance forums.
This would lead me to believe that you have no clue as to what is involved re:00VI.
So, with that out of the way, get a MEVI if you can, but, the real advice: Research the subject until your eyes bleed. After that, do it again. Until then, post REAL questions.
The ?'s in this thread can only be answered by you.
Old May 30, 2007 | 05:58 PM
LiGhtSoUt's Avatar
nmexmax sumed it perfectly mevi is bolt on oovi is abit more of research mevi is more for high end where oovi is all around
Old May 30, 2007 | 06:36 PM
86maxima96's Avatar
I Broke OT
plus, after reading, you will decide if it's worth it or not without a JWT ECU. the way i see it, to get the most out of both, they must be used together.
Old May 30, 2007 | 09:08 PM
ethnic6's Avatar
survey says 00vi because its already proven that it produces more power than mevi, but mevi is very direct and easier to install than the 00vi mod
Old May 30, 2007 | 09:30 PM
TysMadmax's Avatar
think i will go with the mevi since i can not afford trouble with my car which is my daily driver. But it sucks that you cannot run a supercharger. At least thats what I am told?
Old May 30, 2007 | 09:32 PM
NmexMAX's Avatar
dot dot dot ...
Whoever told you that is Where did you get that false information?
Old May 31, 2007 | 07:09 AM
icedout's Avatar
00vi all the way
Old May 31, 2007 | 07:47 AM
Bobo's Avatar
The obvious question is what mods the OP has already undertaken.
You don't start with either of the alternatives you are contemplating.
For example, what kind of aftermarket y-pipe are you presently running?
What is that combined with ...stock airbox, CAI, etc. etc.?
Don't put the cart before the horse!
Old May 31, 2007 | 01:01 PM
TysMadmax's Avatar
I am currently running a stillen y pipe and a greddy catback. And a weapon-r cold air intake. runs great probably going to run some performace headers next.
Old May 31, 2007 | 02:52 PM
Going from ypipe to headers will net you ~6-8 more hp. Why spend the money and time (lots of it) to go with headers when you already have a ypipe? Stick with your plan of MEVI with JWT ECU, or 00VI.
Or, save your pennies and go for boost, whether it's turbo or SC.
Old May 31, 2007 | 02:54 PM
markd248's Avatar
Why is it so hard to write 00vi rather than oovi. It's called 00VI because the parts come off of the 2000-2001 maxima. Hence 00VI.
As everyone else has said get the 00VI if you can install it. However if you're less technically inclined, you should think about the MEVI since it's easier to install.
Old Jun 1, 2007 | 04:55 AM
VQ30DETT's Avatar
courtesy parts now carrys the MEVI again, i just called them they have 2 already to be shipped out for only $379
Old Jun 1, 2007 | 08:57 AM
NCSU_MAX's Avatar
Maximoneypit
MEVI. I see waaaaaaaay to many threads of people having problems with the 00VI. MEVI is a direct bolt-on which was the selling point for me and to me it wasnt worth the extra trouble for an extra few lb-ft.
Old Jun 2, 2007 | 09:00 PM
markd248's Avatar
You could just drop in a rb25det.
Old Jun 3, 2007 | 12:16 PM
sam_918's Avatar
markd248 You could just drop in a rb25det.
Is that what you did? Because I would like to see that. Pics please.
Not gonna hold my breath thou.
Old Jun 3, 2007 | 12:30 PM
Tatanko's Avatar
Bacon Lover
I love my 00VI. It's just as reliable as stock
The OP sounds like he'd be better suited to a MEVI, though
Old Jun 3, 2007 | 12:50 PM
NmexMAX's Avatar
dot dot dot ...
das whut i sed!!!
Old Jun 3, 2007 | 01:47 PM
aznsap's Avatar
if you know what you're doing, 00vi. if you want the easy way, MEVI.
Old Jun 3, 2007 | 05:24 PM
Ceasars Chariot's Avatar
Old Maxima Legend
yeah no trouble with my 00VI setup, cold start you have to keep your foot on the gas pedal and rev lightly and real quick like she is good to go for the rest of the day. The 00VI blows away the USIM when setup correctly.
A good place to start is the 00VI for Dummies thread that should be a sticky, but presently is hidden in the all motor section about 13 pages back.
It was a spin off from those books like windows for dummies, lawnmowing for dummies, etc. I certainly know now how involved the swap can be, and I know heaps more now than I did when we started my swap.
You have to figure out which setup you want to go with, gather up parts, and get started on the swap.
But I say this, if I got through this swap, anyone on the org can do it, especially with the help from your maxima.org "all motor" brothers. People get a bit rough on here with newbie questions, but anyone who jumps into a swap and starts a thread in that section will always get plenty of help to see them through to completion.
00VI for Dummies Thread
http://forums.maxima.org/showthread.php?t=498379
As for the MEVI, I always hear the difficulty level is much less, but I never liked the whole low end loss thingy. You got much more top end but you lose some low end, it can be gained back with upgraded ecu to put you back where you started. But the sweet thing about 00VI is that there is no low end loss, I believe there is low end gain ! And top end simply punishes the USIM.
I used to run pretty consistent 9.0-9.1 1/8 mile times on my way to the 1/4 mile finish line with the USIM, and with the OOVI im seeing 8.7's often and 8.8's easy.
Anyways it sure is cool we have the options for a 4 door japanese family car isnt it ! So take your pick (USIM, MEVI, or 00VI)
Old Jun 3, 2007 | 06:41 PM
markd248's Avatar
See http://forums.maxima.org/showthread.php?t=524267 to get the joke.
You should've also noticed the "".
Old Jul 13, 2014 | 12:10 AM
Evil_Truth's Avatar
D*** answer
Legit question, arrogant.. Were all trying to educate ourselves... All mighty guru...
Old Jul 13, 2014 | 12:40 AM
Evil_Truth's Avatar
Thank you for so much info and guiding me on the right path, very much appreciated... Some on here can be D***, that being said I'm sure you deal with same questions day in and day out... I appreciate the time you put into your answer... Now if I could only find me a complete OOvi... Trying
Old Jul 13, 2014 | 03:39 AM
Please be aware of the date of the last post before you bump and post in a thread. In this case, the thread was 7 years old and your bump wasn't justified as you didn't ask a legitimate question or add relevant and/or helpful information.
Old Jul 20, 2014 | 09:31 AM
96i30azn's Avatar
There are forums where it's okay to start a new thread to ask where your cupholder is - this isn't one of them. The information here is rarer and harder to come by so respect the ones who educate you. Try not to dilute the information or resurrect dead threads because of your ego.
TallTom
57
Oct 14, 2025 05:16 PM
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
