alternator in the 4th gen?
Old May 31, 2007 | 05:14 PM
blimblam's Avatar
i can't seem to find the alternator in the 4th gen. i want to do the big 3 for my sound system but i can't find the alternator. anyone noe where it is? and yes, i do know what it looks like. thanks.
Old May 31, 2007 | 05:21 PM
matty's Avatar
Timing cover, pass side of the motor, right behind the radiator.
-matt
Old May 31, 2007 | 05:51 PM
bigpulve+'s Avatar
FSM?
10servicemanual
Odd question. If you know what it looks like, I'm sure you know a belt runs around it. Follow the belt!
Old May 31, 2007 | 10:45 PM
m00njal's Avatar
Check out this site, has a full walk through guide for removal which I, being a total noob in mechanics and cars, was able to use and replace my alternator in three hours! Worked out fantastic
http://www.motorvate.ca/mvp.php/500
Just MAKE EXTRA EXTRA SURE and take YOUR TIME in figuring out how the belt tensioner works before completely undoing it.
Its fairly easy, jack up the car, take out front passenger wheel, and covers under the car and by the oil filter and have someone help you, should be set.
If you have any questions, PM me.
Old May 31, 2007 | 11:00 PM
maxima985spd
in the trunk right near the jack
Old Jun 1, 2007 | 01:20 AM
MorpheusZero's Avatar
If you can't find it, that would probably be because the 4th gen doesn't have an alternator. Do some research.
Old Jun 1, 2007 | 03:49 AM
slinky87's Avatar
PM me if you need more info
Old Jun 1, 2007 | 05:25 AM
Whitemax's Avatar
Disco Biscuit
And have fun swapping it out if you do it yourself. Its not too hard, but VERY time consuming the first time you do it, due to the location. This isnt a 15 minute Ford alternator swap.
Old Jun 1, 2007 | 10:16 AM
Fast1one's Avatar
Agreed, its such a ***** takes SOOO long...
Old Jun 1, 2007 | 12:37 PM
BlackDOut98LGE's Avatar
I just paid to have mine done last week....$475
Old Jun 1, 2007 | 01:39 PM
maxima985spd
I can do my alternator for $160.
Old Jun 1, 2007 | 03:42 PM
f550maranello2's Avatar
i did mine last night...
u dont have to remove the fans...
all u need to do is remove the ac compressor bolts and push it aside....
then pull out the alternator.... dont get one from autozone cuz i went there and the one that is supposed to fit doesnt.... the bracket is way too wide
i had to go to advance auto parts and pick up the correct one....
Old Jun 1, 2007 | 04:52 PM
KRRZ350's Avatar
And don't forget to disconnect the battery first!!!
Old Jun 1, 2007 | 09:23 PM
just the positive cable...
MAXSE5SPD
Sep 17, 2022 04:00 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
Violator
Sep 9, 2015 10:14 AM
Lowered_a33
Sep 1, 2015 07:49 PM
