I was told this would happen, but I did not believe it.
Old Jun 1, 2007 | 11:34 AM
FormorAccordMan's Avatar
So guys-
I dynamatted my car about 2 yrs ago. I did my two front doors and sealed them really well. I have noticed now that my drivers side door has some play and seems to be sagging a little from the hinge area. if I grab the door while its open, I can move it up and down slightly, where the passanger side if I try the same thing, has no play and the car goes up and down with the door. I am assuming that this happened to the extra weight of the dynamat? Jeez! Now, when I close the door, I think the door is kissing the sill first and then catching the lock. Obviously when the door is closed there is no sign of a problem, but you can definitely hear and feel that the door is hitting the frame first before it closes. Is this adjustable? I dont even know where to begin.
Thanks for your help
Old Jun 1, 2007 | 11:45 AM
Kevlo911's Avatar
Kevlo for President
Loosen bolts, adjust, tighten?
Old Jun 1, 2007 | 11:54 AM
oldngivout's Avatar
Willing to learn
Unfortunately this condition is not adjustable, but it is common, even without the added dynamat weight. The repetitive opening and closing of the driver's door causes the upper hinge to wear excessively. There are after market kits available to renew the hinge pin & bushings. I repair them the difficult but better way by replacing the entire hinge assembly. When you do it this way, the front fender usually must be removed for access to the bolts.
Old Jun 1, 2007 | 11:58 AM
Oh ****. FUNK that.
I guess I will have to baby the door. I'm not messing with it unless it becomes a real issue then.
Old Jun 1, 2007 | 12:02 PM
NAS's Avatar
NAS
its an easy fix, remove the fender change out the hinge, its not going to get any better..
Old Jun 1, 2007 | 12:08 PM
BlackDOut98LGE's Avatar
Just go to a body shop & have them 're-hang' the door...I can't imagine it is greatly expensive...
Old Jun 1, 2007 | 12:19 PM
I was thinking that. Thanks. It certaintly is not gonna get any better
Old Jun 1, 2007 | 03:44 PM
f550maranello2's Avatar
i doubt the dynamat is the problem..
i have 2 layers on... it doesnt way anything...
Old Jun 1, 2007 | 07:57 PM
Benzmcs's Avatar
yea i had the same problem on a ford explorer just buy the hinge kit they arent too expensive and with that kit you dont have to take the door off and its not too difficult... it may not be as good as replacing the whole hinge but it worked for my sagging door im sure it would solve your problem
Old Jun 1, 2007 | 08:55 PM
willard00's Avatar
yea i dont have any dynamat on and i have this problem. i just make sure to slam the door so i know its closed.
Old Jun 1, 2007 | 09:14 PM
Maxima_Joe's Avatar
4th Gen Parts King
You don't have to remove the fender to remove the door.
Old Jun 2, 2007 | 06:16 AM
Mobscene's Avatar
just buy a new hindge pin kit.
alahjahwan09
18
Sep 21, 2015 09:12 PM
jwright36
Sep 8, 2015 11:45 AM
