300ZX Fuel Filter
Old Jun 5, 2007 | 10:36 AM
aih98max's Avatar
scoobystoned...
300ZX Fuel Filter
I just wanted to make sure I was correct about this before I bought one. You can use a 300ZX fuel filter on a 4th gen with no extra modification needed, right??? What are the postivies of using the 300ZX filter instead of the maxima one??? Thanks guys.
Old Jun 5, 2007 | 10:39 AM
VIP Maxima
yes u can use a 300zx filter. its bigger so it will last you a bit longer.
Old Jun 5, 2007 | 10:52 AM
[s3]'s Avatar
No advantages
Old Jun 5, 2007 | 10:59 AM
bkmax98's Avatar
It suppose to have double the life span of the maxima fuel filter. My car right now is using the 300zx fuel filter
Old Jun 5, 2007 | 11:15 AM
Noladol's Avatar
Good to know. Thanks.
Old Jun 5, 2007 | 12:36 PM
andrei3333's Avatar
i switched to a 300zx fuel filter, no mods required, one advantage is double the life span (arguable because some here say the fuel filter filters better when its dirty thus u can keep it on longer). get the 96 TT 300zx fuel filter
Old Jun 5, 2007 | 12:47 PM
Streetracer95GX
How can a dirty fuel filter be better? I know changing it to a more flowing filter is better. I was at the track with my j30 and i ran a 16.05 @90 for two runs. When i went back in the staging lane i changed the fuel filter to a high flow fuel filter, those tubes were like glued on.., ran one last time and got 15.91 @ 90 ,it helps your car get off the line a little bit better. So don't expect much from doing this.
Old Jun 5, 2007 | 12:58 PM
Specialeded's Avatar
Now I have heard it all.
Old Jun 5, 2007 | 01:31 PM
andrei3333's Avatar
maybe ur filter was clogged to the point of choking off the supply. there is a fine line betwee na dirty filter that is still operable, and a clogged filter.
search and u'll find out, i am not about to repeat myself for the gazzilionth time
Old Jun 5, 2007 | 01:39 PM
G4nismo's Avatar
lolllll
anywayz, just go w/ the 300. clampin it on is the tricky part cause its bigger than the max's. just get sum zip ties or sumthing
Old Jun 5, 2007 | 01:40 PM
wetzelman1's Avatar
I just got one since I figured I needed a new fuel filter and people recomended it. Don't expect any performance boosts, but I don't see how a bigger fuel filter could hurt at all. Doesn't require any modifications, but the tubes are much more difficult to get on since it's slightly larger.
Old Jun 5, 2007 | 01:47 PM
G4nismo's Avatar
well after i changed my max fuel filter to a "high flow" 300 zx filter,
i slashed my 1/4 time by 2 sec!
so there has to be performance gains dude!
Old Jun 5, 2007 | 02:11 PM
mtrai760's Avatar
'Trynna' is not a word
Or your old filter was so damn dirty that it was choking off fuel from your engine. That was not a performance gain, you just got back to where you should have been with a properly operating fuel filter.
Old Jun 5, 2007 | 02:12 PM
th0ught's Avatar
I really never have noticed an increase in difficulty with sliding the hoses on.
Old Jun 5, 2007 | 02:13 PM
glenmoormax's Avatar
10 psi
i have the 300zx on both my maxima's... they work great.
Old Jun 7, 2007 | 07:06 AM
aih98max's Avatar
scoobystoned...
hows salt lake man? i miss it, i want to come home. how are the maximas runnin? got any old parts lying around to sell me? lol
Old Feb 13, 2008 | 11:26 AM
shadyonedeath's Avatar
can these be bought at AutoZone/Kragen/Pepboys?
Old Feb 13, 2008 | 11:49 AM
VANGtastic97's Avatar
most likely yes, but not genuine nissan parts. check autozone.com
Old Feb 13, 2008 | 12:11 PM
ROCKART's Avatar
wants an I35
lolllll
naw you can just bend the existing bracket outward a bit and it fits perfectly in there. i didnt add or subtract anything to get it to sit right.
actually the apertures are almost identical. there is really no difference between the two other than the width of the actual cannister.
yes
refer to above
no, stick with nissan OEM parts for sensitive stuff like this
call Dave Burnette at South Pointe Nissan - 888-254-6060
and tell him you are a member of maxima.org
or call Courtesy Nissan
http://www.courtesyparts.com/secondtier_a32.html
I think they are like 12 bux, but dont quote me
Old Feb 13, 2008 | 01:30 PM
5alive's Avatar
Do unto others...
Hey
Maybe this should be in a sticky somewhere?
Old Feb 13, 2008 | 01:55 PM
aih98max's Avatar
scoobystoned...
wow, im the OP, who ressurected this thread?
Old Feb 13, 2008 | 01:56 PM
NmexMAX's Avatar
dot dot dot ...
Today, 12:26 PM #17
shadyonedeath
can
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
Justin Kroll
Oct 1, 2015 07:03 PM
