Park to Reverse
Old Jul 15, 2001 | 10:50 AM
97MaxGLE's Avatar
I own a 97 GLE with 22K miles on it. When shifting from park to reverse I realized more resistance than through the other gears. Sometimes is happens and sometimes it doesn't. In the other cars I've driven I haven't noticed this. Is this normal for the Max or something I should have checked out.
Old Jul 15, 2001 | 11:10 AM
pawn's Avatar
Yes...I have noticed this with my maX as well..but i am unsure if it is normal or not......
Old Jul 15, 2001 | 11:15 AM
SMakin'Max's Avatar
Your best bet to avoid this is When u park ur car pull up the parking brake up BEFORE u let go of the brakes. This way if your on a slope the cars weight rests on the brakes not on your tranny, This should help.
Old Jul 15, 2001 | 11:19 AM
Daniel B. Martin's Avatar
Your Maxima has a safety interlock which prevents shifting out of Park unless the brake pedal is pressed. Perhaps the shifter release solenoid is sticking and interfering with normal shifting.
Old Jul 15, 2001 | 11:41 AM
97MaxGLE's Avatar
Thanks. Maybe that is the reason. I'll do that from now on.
Old Jul 15, 2001 | 11:55 AM
pawn's Avatar
but i thought that if your brakes were really hot...(say from hard braking...or just driving for a while) and you pulled your e-brake...you would/could warp the rotors....I got this info of Chestons site!
"NEVER EVER pull your ebrake after extended periods of hard braking. You'll warp your rotors.. not a good thing."
Old Jul 15, 2001 | 12:14 PM
SMakin'Max's Avatar
I Never heard of that but i might be right. I've been doing I on my max for years and never had a problem. You just pull up a couple notches and that's it. I don't think it puts that much pressure on rotors.
Old Jul 15, 2001 | 03:28 PM
RedMax95's Avatar
ya, i have also noticed the difficulty between park and reverse is more than the other gears, it usually happens when i park on a hill, also my stock shifter is now a custom on top of a short cut bar, if that matters
Old Jul 15, 2001 | 04:28 PM
Eric L.'s Avatar
You won't warp your rear brakes by using the ebrake unless you've been driving REALLY hard, like on the track. I mean, slamming on the brakes repeatedly, which is highly unlikely in a street situation.
What I do is shift to neutral, set the ebrake, go off the foot brake, and then brake and shift to park. I find that eliminates the tough P->R shift.
Old Jul 15, 2001 | 05:03 PM
WaarrEagle's Avatar
It has been stated above but I will do it again. The problem is that you stop your car, put it in park, and the car rolls a few inches and I guess the gears a forced against each other. Then when you go to shift out of park its hard. Do what SMakin'Max said to do to avoid this. About warping the rotors, I only use the e-brake when I park on a hill. My dad uses it ALL the time and he has never had any problems. I don't think it would be a problem unless your rotors are REALLY hot.
Old Jul 15, 2001 | 08:17 PM
Vyrus's Avatar
RE: Shift Resistance...
I have noticed this and I took it to the local Nissan dealer. They told me it was normal, so I "test drove" a new SE Automatic and this happened here as well. Perfectly normal. By the way, DAMN YOU HAVE LOW MILES!
Old Jul 15, 2001 | 09:34 PM
97MaxGLE's Avatar
Re: RE: Shift Resistance...
The car was sold on s low mileage lease in dec. of 97. I bought it with 19K. I plan on keeping it a long time.
Old Jul 15, 2001 | 11:52 PM
MaXXX's Avatar
Parking Brake
*Before* putting your car into park from drive/reverse when done for the night, engage parking brake. *After* putting your car in gear when its all warmed up and ready to go, disengage parking brake. Its there for a reason. Your body may not notice the ever-so slight slope where-ever you parked, but your car will. The reason why its hard, your car is sitting on the tranny. Not good. Repair to parking brake: <$100CAD. Repair: to tranny %5000+
MaXXX
Old Jul 16, 2001 | 12:24 AM
Mr. Nismo's Avatar
I agree!!!!!
jmlee44
Oct 2, 2022 02:13 PM
gigabyte
Jan 6, 2017 06:05 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
