engine removal how to?
Old Jun 9, 2007 | 06:14 PM
maxine'sMan's Avatar
I've searched this site and others and I am not able to find any comprehensive engine removal how-to's that are fourth Gen specific.
I have the FSM and I can see that they say to take it out the bottom. I am planning on doing this at home, or at least I woud llike to. Has anyone yanked one out the top? Anyone know how to get the car off it once it's been dropped?
Any input is appreciated.
Thanks.
Old Jun 9, 2007 | 06:24 PM
semaj3708's Avatar
FEELS GOOD TO BE GANGSTA
Proly better luck in the all motor forum
Old Jun 9, 2007 | 06:48 PM
pmohr's Avatar
No more Maximas...
Pull the wiring harness (takes maybe 10 minutes, tops). Intake, batt, axles, shift linkage, slave cylinder and unfasten the line if 5MT, y-pipe, hook up the hoist, undo motor and trans mounts, yank the ***** out.
Quickest I've ever had a motor out from start to finish is maybe 30 minutes, this being on my friend's Integra. Of course, that was it's 4th time coming out, so we were a little familiar.
EDIT: Also, obviously remove the belts, PS pump, and compressor.
Old Jun 9, 2007 | 06:52 PM
nismology's Avatar
Buy a haynes manual.
Old Jun 9, 2007 | 06:55 PM
EnervinE's Avatar
i has college
Check the 3.5 swap guide in all motor forum.
Old Jun 9, 2007 | 07:02 PM
nismology's Avatar
Yea I forgot that tavarish actually went into detail.
http://forums.nycmaximas.org/showthread.php?t=19270
Old Jun 9, 2007 | 07:14 PM
KRRZ350's Avatar
Yeah but he removed it from the top. I dropped an engine and trans out of a '96 auto just yesterday, it took about 1 hour & 15 minutes!! It's suprisingly so easy to do on these cars, dropping it from the bottom with trans attached FTW! Just use the engine hoist to pick up the whole car about 3-4 feet onto a few railroad ties or cynder blocks (not recommended). Once the engine is dropped if you didn't have the car high enough you can use the engine hoist on the car again to get it even higher. Just wanted to add to above list, a/c lines, power steering lines, fuel lines, and heater hoses.
Old Jun 9, 2007 | 07:52 PM
Perfect!!! I was hoping I wouldn't have to lift the whole car..
Thanks.
Old Jun 11, 2007 | 11:41 AM
KRRZ350's Avatar
Dude it's SOOO much easier to lift the whole car then drop it out, just speaking from experience here, do what you want........
Mar 12, 2020 12:06 AM
knight_yyz
Oct 24, 2015 08:05 AM
Colossus
Sep 9, 2015 05:46 AM
