Rewire fog problems.....
Old Jul 15, 2001 | 05:47 PM
twankz's Avatar
I rewired my fogs, but it doesn't work. What could the problem be? I did everything right? Could it be the fogs are not 12V.
Old Jul 15, 2001 | 06:54 PM
zagato27's Avatar
Fog rewire
This site has the best description AND pictures for rewiring your fogs. I printed out their description with pictures and did the job. Worked like a charm
I suggest you go over your work with these instructions to see if you made a mistake. Good Luck.
http://www.voicenet.com/~breaux/car/fog/fogrewire.html
Cheers
Old Jul 15, 2001 | 07:14 PM
MegaMax's Avatar
Did Ya do this..?
At Meet I was asked how I got my Fogs to go on with my Parking lights... Here is what I did...
I can't take credit for ANY of this as I found it off of Jeff's The MegaMax A.E. Website.
To see other Mods available go to: Nissan Maxima MaxFAQs.
All directions will be referenced how you see it when looking at it, not absolute sides of the car. i.e. when you have the hood open and you're looking at the engine, the steering column (in the US) is on the RIGHT!
1) Locate the relay box on the left side of the engine bay, which is in front of the strut tower. On the lid of this box you will see items such as "CORN LIGHT", "FR FOG LIGHT", and "AIR CON".
2) Right in front of this box is the coolant reservoir. It is held to the fender with two 10 mm hex bolts. Remove the bolts and pull the coolant reservoir away from the fender. We need to temporarily relocate this reservoir because we'll need this space to work on the wiring. I suggest you lean the reservoir on the radiator between it and the engine block... It fits there quite well without falling and making a mess :-)
3) Open the relay box. This is really easy. Standing on the [absolute] right side of the car in front of the RF wheel, pull up on the right side of the lid on that little latch.
4) You will need to remove the two relays on the far right and the relay on the far left to be able to remove the bolts holding the relay box to the chassis. To do this, you will notice that each relay is held down with a little clip, which is on the side of the relay facing the engine block. Using a flathead screwdriver, pull that clip away from each of the aforementioned three relays and pull the relay up. These relays *should* be identical but you never know, so remember which relay is from which location and put them back in the same locations.
5) Remove the two bolts holding the relay box to the chassis. There's also a "leg" holding the relay box to the wheelwell protrusion, under where the coolant reservoir usually is. (Aren't you glad you removed it?). Pull up on this arm, jiggling it sideways in the process to help it come out.
6) Now look at the sides of the relay box. You will notice that the relay box is actually two pieces held together -- like a Rubbermaid microwaveable box... the lid comes off. In this case, the lid is the "Grill" that holds all the relays in place. You will notice on the sides of the relay box that there are fasteners holding the lid on. If memory serves me correctly, there are three on each of the long sides and two on each of the short sides. Unfasten them all.
7) At this point, you would expect the relay box to open, but it won't. There are two more clips to unlatch. These clips are on the outboard side of the relay box on the top edge. They're between the bolt-arms that connect to the chassis, and they're very insignificant-looking, just sticking upward in a hole. (Keep your minds out of the gutter, guys). While pulling the lid up from the opposite side (which is already "open"), push each of these clips towards the middle of the relay box. You will hear a click and the side you just unclipped will come free.
8) Pull the lid upwards, exposing the undersides of all the relays. Lots of wires, eh? Now find the original TOP lid of the relay box, which has all the labels of the relays. You will notice that the fog light relay is the top right, when looking from above. This is one of the relays you removed to get to the bolt holding the relay box to the chassis.
9) Turn on the headlights and whip out your sharp-needled voltage light. Poke the terminals of the fog light relay connector with it -- make sure that the left (when looking at it from above from the absolute right side of the car) connector has +12V. There will also be another terminal with +12V, but the left one is the important one. If the left one does not show +12V with the headlights on, then something's drastically different with your car. If that is the case, please email me at Andi@airmail.net to notify me of this. Also, If there is anything else in this document that contradicts your car's characteristics, please stop and email me.
10) Assuming that Step 9 showed the left terminal to have +12V, flip over the relay-holder grill and look at the underside of the fog light relay holder. Remember, we've flipped it so what was the left terminal is now the right terminal -- i.e. the terminal on the closer to the center of the relay box. This is the signal terminal. There should be a green/yellow-striped wire leading to this terminal. (There might also be a different green wire going to another terminal -- ignore that one).
11) Tug on the green/yellow-striped wire leading to the signal terminal to get a decent length of it to do surgery on. Cut the wire. Wrap the end coming from below with electrical tape so as not to cause a fire hazard... You don't want a +12V wire hanging naked in the relay box do you? Now connect a long (I'd say three foot), well-insulated, thick wire to the end of the wire hanging from the relay. I don't know which method is best... I used one of those plastic thingees that takes two wires and stabs them with a piece of metal, which conducts the electricity. I then wrapped this well with electrical tape so as not to cause the aforementioned fire hazard.
12) Find the best route for this wire to exit the relay box. Maybe you could drill a nice small hole in the bottom of the relay box? Here's what I did: route this wire over the right edge of the bottom part of the relay box. Then put the grill back on... You'll notice a perfectly-sized gap between the walls for the wire. Fasten all the clips of the relay box's grill's lid and squeeze the two together well to get all the clips tight. This is especially important for those two hidden clips that held the box at the last part of the opening procedure... remember?
13) Put the relay box back in its original position and fasten it's leg back to the wheelwell protrusion by just pushing it down into the hole. Then use the two bolts to fasten the box's arms back onto the chassis.
14) Put the three relays you removed at the beginning back into the relay box in their original positions. Put the cover (the one with the labels) back on the relay box.
15) Optional: to test the setup: turn on the foglight switch and leave the headlights off. Extend the new wire coming out of the relay box over the engine and touch it to the battery's positive battery terminal. The foglights should turn on. Why? This is the signal wire for the foglights -- whenever this wire has +12V *and* the foglight switch is on, the fogs should turn on. We will now connect this signal wire to the side marker light in the bumper -- that way, whenever either the parking lights or the headlights are on, the fogs will have the signal to run -- i.e. they will have "permission" to turn on according to the foglight switch.
16) Gently pry off the right front side marker lamp using a flathead screwdriver wrapped in a clean cloth. Disconnect the wire coming from behind it. Put the side marker light itself away for a minute as it's the WIRES that we're concerned with. [Note: you might want to unscrew and disconnect the turn signal as well to be able to pull the wire farther out.]
17) Route the new wire coming out of the relay box through the fender to the side marker light. This is easier than it sounds -- right below the relay box there's a very large hole in the inner fender. You can literally fit your arm into it (take your watch off first) and just push it all the way through. Then find it through the side marker's hole in the bumper and pull it out. Then remount the coolant reservoir back in its original position.
18) Right behind the wiring harness for the side marker light, there's two wires that immediately hide inside an accordian-type protection tube. Cut enough of this tube off (about an inch...) so that you can splice the new wire from the relay box to the red/blue-striped wire coming from the wiring harness. Now splice the new wire to this red/blue-striped wire. I used the same method as in the relay box. Don't forget to "terminate" or cover the end of the new wire with electrical tape if it doesn't end inside the splicing instrument. Electrical tape is your friend.
19) Connect and reinstall the turn signal and side marker light in the bumper.
20) Finished. Now test the new setup by turning on the parking lights and enabling the foglight switch. Then turn on the headlights and blink the highbeams... foglights should remain on.
Old Jul 15, 2001 | 09:23 PM
twankz's Avatar
did all that
...and it won't work. I didn't use a voltmeter to seee how many volts it had, but I used the same green/yellow wires as i was instructed.
Also, I have a '96 i30, would that be the problem??
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
Calabar
Oct 5, 2015 09:57 PM
