Help CV BOOT broken still driveable?
Old Jun 14, 2007 | 07:57 AM
kismias7's Avatar
My CV boot is ripped and grease is coming out and covering some of the underside of my car. I also hear a ticking when i drive under 10mph, in reverse or forward and the noise will stop(bearing?). Will driving hurt the car even more? Will it mess with a bearing or the cv joint? I am getting an entire axel put on next week and the mechanic told me this includes the cv joint and boot along with bearing?
Old Jun 14, 2007 | 08:03 AM
WhiteA32's Avatar
If you don't know how long the CV was broken for, just buy new axles... The car is drivable. If you getting new axles, then don't worry about it.
I have had torn boots since oct, and I am still good.
Old Jun 14, 2007 | 08:12 AM
Chunger's Avatar
My other car is a Hybrid
Sounds like you CV joint is already bad because it has been leaking for a long time. You'll need to replace the joint too. If you catch a torn boot early and replace it (and the grease inside) you won't need to replace the joint due to it running "dry".
Old Jun 14, 2007 | 08:52 AM
XJinCT's Avatar
<3's the all motor section
its fine. just makes a horrible noise after a bit, by then you should have it replaced. when you get the money change it basically.
Old Jun 14, 2007 | 11:24 AM
Steve68's Avatar
Dirty job when a the grease has slung out, but driveable,
Old Jul 23, 2007 | 06:13 AM
gooroo's Avatar
Does anyone know of where a step by step how to is for this xle replacement procedure? What tools are needed etc.
Old Jul 23, 2007 | 07:56 PM
spddmn1's Avatar
My dad been driving with torn boots on his for about a year. Found out how much it's going to cost to replace both sides & he kinda said maybe before winter
Old Jul 23, 2007 | 08:23 PM
maxima985spd
by now I'm oblivious to the clicking noise.
Old Jul 23, 2007 | 10:34 PM
97NisMaxSE's Avatar
dont drive on dirty roads or gravel. itll really get up there and dry out the joint if its been broke for awhile. roughly $30 for a new one. pretty easy job. if u get it done at a shop its $100. so its best to get the whole half shaft replaced because it will cost the same. ive had this happen 3 times
Old Jul 24, 2007 | 07:16 AM
twizm's Avatar
i second this! it's still driveable... but we suggest not on dirty, sandy roads...
Old Jul 24, 2007 | 06:44 PM
Eshelon's Avatar
I'm looking at doing my Axles (same issue as OP). I've had Axles replaced on other cars before, so I'm familiar with the tell-tale signs (clicking, poping). Anyway, I went to O'riely for the parts today and they're asking my if I have some kind of special transmission. I have a '95 SE manual, and he says it's not enough information, and I need to know what kind of manual transmission I have. How do I figure that out so I can get the right parts?
Old Jul 25, 2007 | 03:55 PM
Eshelon's Avatar
Still looking for some advice here. I hate bumping but I gotta buy these axles soon.
Old Jul 25, 2007 | 04:36 PM
JwaxMax99's Avatar
They will ask if you have ABS or not. And if you have a limited slip trans. or not.
Old Jul 25, 2007 | 07:46 PM
Eshelon's Avatar
That sounds right. Limited slip trans. How do I how if I have that or not? :P
Old Jul 26, 2007 | 07:21 AM
97SEdriver's Avatar
this place is dead
why do you have to buy these soon?
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
knight_yyz
Nov 1, 2015 01:34 PM
Violator
Sep 9, 2015 10:14 AM
