OEM wheel specs
Old Jun 17, 2007 | 05:04 PM
BLACKonBLACK98's Avatar
Former Vendor
OEM wheel specs
1st of all, i tried to search and looked through stickies. just couldn't seem to find the info on oem wheels specs. lil help?
Old Jun 18, 2007 | 12:02 AM
black_maxed95's Avatar
i think its in the owners manual
Old Jun 18, 2007 | 12:20 AM
pmohr's Avatar
No more Maximas...
What exactly about them? For yours, I believe it's 16x6.5, obviously 5x114.3, no idea on offset.
Old Jun 18, 2007 | 06:29 AM
NmexMAX's Avatar
dot dot dot ...
Any particular reason you're seeking this information?
Old Jun 18, 2007 | 06:39 AM
max ride 41's Avatar
offset is 32 to 39 from what the book told me
Old Jun 18, 2007 | 10:26 AM
Former Vendor
1. need everything size realeted... diameter, width, offset, tire size...
2. i'm pulling my max out of storage after a couple yrs. going V.I.P. style (ie low-low drop, big wheels). looking @ 20 x 7.5 w/ 42mm offset for the front so they'll tuck under the fenders.
Old Jun 18, 2007 | 11:12 AM
NmexMAX's Avatar
dot dot dot ...
20 x 7.5" I bet that looks odd, huge dia., tiny width. That's a safe diameter and offset in that you wont have to worry about rubbing.
I've had 8.5" wide and 32mm and it doesn't rub.
Old Jun 18, 2007 | 12:10 PM
Former Vendor
yeah... wierd size. i'm more worried about hittin the inside at full turn than the fender. wonderin if 42mm is too much but i think factory is 40mm so it should be ok.
Old Jun 18, 2007 | 01:33 PM
NmexMAX's Avatar
dot dot dot ...
To get everything straight, the higher the value, the more inward the wheel will sit & vice versa.
Old Jun 18, 2007 | 10:07 PM
MorpheusZero's Avatar
I'm pretty sure SE 16s were +40 or +45, but 16x6.5 sounds right.
Old Jun 19, 2007 | 02:54 AM
maxpeed96plat.'s Avatar
VIP is cool- but you know going 20" will throw of your speedo, 42 offset is too much you'll rub, anyways 42 o.s. doesn't sound right for a wheel thats only 7.5 wide and 20. I'm no wheel expert, just go to tirerack or wheelmax and compare specs most 17-19's are at 35 o.s. if you surpass that spec you'll probably have turning issues> wheel bearing issues-> because your surpassing the geometry range of components, powersteering issues because your rack and pump will suffer via more exertion. good luck on your decision just somethings to consider, check out the brake & susp forum.
Old Jun 19, 2007 | 06:23 AM
NmexMAX's Avatar
dot dot dot ...
Not by a whole lot w/ 235/30-20's (~1.5%)
I have +45, 8" wide and no rubbing. Also have tried +40, 8" and no rubbing.
Old Jun 19, 2007 | 06:35 AM
Fr33way™'s Avatar
Wild for Width
Newsflash: 20x7.5 is NOT VIP.
Old Jun 19, 2007 | 06:36 AM
NmexMAX's Avatar
dot dot dot ...
Old Jun 19, 2007 | 08:58 AM
Former Vendor
heh... knew it couldn't go too long without somebody hatin. thanks for all the info. though.
newsflash (fr33way): 20x7.5 in the front may not be hardcore V.I.P. (just like taking some emblems off isn't really shaving your trunk now is it?) but hopefully i'll be able to turn without rubbing while dropped rediculously low. givin up a (very) lil style for functionality, by using wheels that weren't really made for our cars to accomplish the over-all goal (ie rx7 wheels for weight reduction). maybe if you did some research first, you wouldn't be ridin 5mm spacers hater.
Old Jun 19, 2007 | 01:02 PM
I guess if ur going VIP, performance isn't an issue- personally i wanna know exactly how fast i'm going -even ~1.5% to me is out of the question. Like i said i'm no wheel expert, u can put any size wheel on ur max i've seen 26's on one, but as i said you'll throw ur geometry off also suspension travel is something to consider- please don't let ur wheels tow in you'll go through a lot of tires and IMO it doesn't look good- a properly alligned wheel sitting flush with body panels looks best IMO. do as u please what looks good to u is what's important. peace!
Old Jun 19, 2007 | 03:02 PM
NmexMAX's Avatar
dot dot dot ...
Even if you had the exact same tire size as stock, the gauge itself is not very accurate coupled with the age/mileage of the tires.
Same general principle goes for RPM, ECT & fuel gauges.
Old Jun 19, 2007 | 03:33 PM
phenryiv1's Avatar
Mod her. Ate her.
I have the full chart of nissan wheel specs. I'll look around.
Subscribing.
Old Jun 19, 2007 | 03:48 PM
Former Vendor
i want to go lower than being flush would allow. i'll be on coilovers so suspension travel won't be as much of an issue as geometry. i've been checkin out the susp & brake forum and it seems theres not much you can do besides flip the tie rod. give a lil get a lil.
Old Jun 19, 2007 | 03:56 PM
brandnew's Avatar
Wish I knew wtf all of this meant daaaaaaaaaaaaaaaaaaaaaaamn
Old Jun 19, 2007 | 08:19 PM
Ok, I learn something every day thanks
Old Jun 19, 2007 | 08:34 PM
Tver_Chupra06's Avatar
ok is it possible to put 96 or 99 maxima wheels on a 95 max? what has to be changed? can it be done at all?
thanks
Old Jun 19, 2007 | 09:15 PM
Have you considered bagging the max? I'm sure there has to b an application for it out there, just a thought.
Old Jun 20, 2007 | 02:19 AM
Fr33way's wheels > any set of dubs, ever--ESPECIALLY 7.5Js. 20x7.5 will look plain silly.
And 5mm spacers are a small price to pay for <14lb wide wheels that can be had very cheap and look more or less OEM.
Old Jun 20, 2007 | 07:01 AM
Fr33way™'s Avatar
Wild for Width
Well I guess since you made it personal then I will make my reply the same.
Maybe those are opinions on a (wait for it...) public forum?
That is true, it's actually pretty lame overall.
Not really sure what this is referring to. If it's to me, did I go around saying I have a m4d tyt3 JDM VIP Cefiro slippery trunk? Not really.
More a factor of offset, there are pleny 4th gens on 20s (and a few on 21s).
People that don't know cars (or VIP) will be impressed, so I guess.
Maybe, in the research I found I would be using 5mm spacers and ordered them before I got the wheels. I knew the offset, backspacing, aspect ratio, distance from caliper, distance from ebrake cable, and distance from body all before I got them home.
If you had just said "I want to put skinny 20s on my car", I would have bypassed this thread. But since you mentioned VIP and (oh really?) I know about the VIP scene (both here and Japan) I thought I would chime in. Please don't take it like a little girl with gum in her hair.
Old Jun 20, 2007 | 11:06 AM
Former Vendor
opinions are great (i even like negative ones) but i asked for facts.
did you even read the thread or did you just search vip and look for the pretty highlighted letters?
good taste is universal. thats why we're bickering over the 1" width difference of a front wheel, instead of the overall idea. technicalities. and i promise you'll at least respect it, if not be impressed.
so what i'm hearing is you could've helped, instead you wanted to show out.
ha ha.
and for the pom-pom section... not interested in savin weight or lookin factory... GOOOO FR33WAY!
on the upside, not getting any actual feedback has led me to back to thinkin wider wheels and less drop. thread dead.
Old Jun 20, 2007 | 11:10 AM
Fr33way™'s Avatar
Wild for Width
Fact: 20x7.5 is STILL not VIP. It's poser.
If you want info on the lowest drop on 20s PM shavedmax. He is on 20s and bagged.
Old Jun 20, 2007 | 11:11 AM
Former Vendor
not baggin, but thanks for the attempt at helpful information
Old Jun 20, 2007 | 11:48 AM
NmexMAX's Avatar
dot dot dot ...
thread dead.
Delete your first post, and the entire thread should disappear
Old Jun 20, 2007 | 12:51 PM
Fr33way™'s Avatar
Wild for Width
It has nothing to do with him being bagged, he is low and on 20s. You are terrible at reading comprehension.
9aj9
Apr 5, 2020 12:11 AM
captchaos
Mar 15, 2016 12:18 PM
aminus21
Sep 12, 2015 04:53 PM
dcam0326
Sep 8, 2015 11:02 PM
