Iacv
Old Jun 18, 2007 | 07:22 AM
hiren_patel_83's Avatar
Iacv
Anybody have any pictures or diagrams on how to change or clean your IACV. I believe that's the problem I'm having. When I'm sitting at a traffic light the RPM slowly moves to 500 - 600 - 700 and then comes back down.
Correct me If I'm wrong.
Old Jun 18, 2007 | 07:41 AM
Neo Raven456's Avatar
It could be a number of things that would affect that, including TB/MAF/Air Filter, even a bottle of FI cleaner could clean it up.
For ease of things, take out your Intake assembly, then disconnect the 4 connectors. On the IACV assembly you'll have 4 12mm bolts I believe, as well as a phillips head screw holding the fourth connector bracket.
Take the screw out and just let the connector/assembly there dangle. Unbolt all 4 bolts and take off the IACV, watch for the metal gasket. You could also use to replace that gasket at this time.
Someone chime in here, if I remember right you clean the gold cap you see, and on the opposite side of that you can unscrew that brown thing and clean in there as well. Watch for a spring assembly, I remember there being one in there somewhere
Old Jun 18, 2007 | 08:11 AM
zoman85's Avatar
I've cleaned mines twice before i decided to replace it. The CEL came on and i cleaned it the first time, and i had it cleaned again, and the CEL light came back on. Even though it was a bit expensive (i believe around $130 for an aftermarket), i ended up replacing it and the code never came back.
Old Jun 18, 2007 | 08:13 AM
what did you clean it with? Do you think it might be the solution you used to clean it with?
Old Jun 18, 2007 | 11:12 AM
andrei3333's Avatar
here is from when i did this:
did the TB at the same time as well as changed the KS. make sure u replace the metal gasket, never reuse gaskets, its only a few dollars. do not adjust the iacv screw until u put everything back and check ur idle - or even wait a week or more for it to settle down on its own.
Old Jun 18, 2007 | 11:13 AM
you are the man
Old Apr 3, 2008 | 01:58 PM
caseymaxima's Avatar
CAn you elaboate on the idle adjustment screw? After a cleaning my idle is up high, just wait a bit?
Zack
Old Apr 3, 2008 | 03:43 PM
Snypa's Avatar
^^^^how about adjusting it to your likings.
schmellyfart
Sep 25, 2015 04:47 PM
junito1
Sep 23, 2015 12:14 PM
bumpypickle
Sep 20, 2015 08:22 AM
Jamie Bowen
Sep 6, 2015 09:59 PM
nbstriker10
Sep 4, 2015 04:26 PM
