Need some help with my car
Old Jun 24, 2007 | 02:47 AM
supermanrox305's Avatar
Tonight i was driving on the highway at about 80 or 90 tops. I was getting off the highway when i noticed that the motor was at about close to 2000 rpm and i was not revving the motor at all. So i stop and adjusted the idle screw and that fix the problem. I just got home and the car did it again. What could the problem be. Please i really need some help with this. Thanks.
Ps- i have an auto. If that helps.
Old Jun 24, 2007 | 05:54 AM
XJinCT's Avatar
<3's the all motor section
could be the kickdown
Old Jun 24, 2007 | 01:48 PM
What is the kickdown ?
Old Jun 24, 2007 | 05:21 PM
Ok so today i swap the maf's to see if it was that and then car is still doing it. I also checked the tps and its fine at 0.572 at idle and 3.986 at open. So what else could be the problem ?
Old Jun 24, 2007 | 06:23 PM
99BlackMaxMS's Avatar
Check the IACV and adjust the idle there
Old Jun 25, 2007 | 04:30 AM
Im 00vi so i dont have a iacv. And it does it the moment my car turns on and even when its warmed up.
Old Jun 25, 2007 | 05:34 AM
dralucard's Avatar
did you check for any codes?
Old Jun 25, 2007 | 07:33 AM
I did go to advance today and i got 3 codes
p0505 idle control system
p1105 manufacturer control fuel air metering
p0171 system too lean bank 1
Old Jun 26, 2007 | 05:38 AM
dralucard's Avatar
0505 is nothing
1105 is improper shifting into 3rd gear(auto tranny problem?)
0171 is not a good code
I would clear the codes, drive around for a while and then check the codes yourself and see what pops up.
Old Jun 26, 2007 | 11:10 AM
Wassup2114's Avatar
0505 is nothing
The codes you get from a scanner are different than the ones you get by pulling them manually. What he listed are the correct codes.
Old Jun 26, 2007 | 09:51 PM
NElsonAQuino's Avatar
bad throttle sensor?
Old Jun 26, 2007 | 11:45 PM
maxpeed96plat.'s Avatar
Clean ur IACV and TB, clean ur MAP sensor--if it continues check for vacuum leaks and ur EGR for leaks-- how's your air filter?
Old Jun 27, 2007 | 05:43 AM
dralucard's Avatar
doh! didn't realize that, sorry. anyway, i would still clear the codes manually and see what comes back.
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
Balkins
Aug 12, 2015 06:39 AM
acw
Aug 7, 2015 04:20 PM
yat70458
Aug 3, 2015 01:16 PM
