driveaxle boot has hole
Old Jun 24, 2007 | 01:27 PM
Cdg2125's Avatar
P.Side driveaxle boot has a hole big enough to put my thumb into. Lots of grease on the outside, but that is to be expected. Does this need to be fixed right away? Or do I have some time? Judging by how much grease there is, it's been torn for a while. I won't put off fixing it very long, but need to know if it should be fixed right away. Can I pick up the boot alone or what?
Old Jun 24, 2007 | 01:38 PM
Albert's Avatar
I would replace it as soon as possible. You don't want the grease to dry up. It's a sloppy job to replace if you don't know hot to do it so might as well let a mechanic do it. It shouldn't cost that much. If you are going to buy the replacement boot, don't get it from the dealer. Even though the quality of the boot is better, you'll need to remove the entire axle to replace that kind of boot. At that point you might as well replace the entire axle that comes with the boot.
Old Jun 24, 2007 | 01:43 PM
Cdg2125's Avatar
well where should I get the replacement boot then if not from Nissan? I'll probably have the family mechanic do it. He does work for the family when I can't fix things so it won't be too bad of $$. I don't know why I would buy the whole axle instead of the boot. Raxles go for $120-$160, I'm sure the boot doesn't cost that much ha.
Old Jun 24, 2007 | 03:04 PM
pmohr's Avatar
No more Maximas...
Well as you say, it's likely been torn a long time, you don't know how long and in what conditions you were driving around with a torn boot there. The joint is most likely contaminated from dirt, dust, etc. Does it click when making turns?
You can replace the boot with a split type that will allow you to leave the axle in the car, but those basically suck and there's no real guarantee that the joint is okay and won't fail soon after the boot replacement.
If you don't want to go raxles, just get a reman from an auto parts store, about $50-60 + core, and probably the same labor cost for R&R.
Old Jun 24, 2007 | 03:07 PM
XJinCT's Avatar
<3's the all motor section
what he said.
Old Jun 24, 2007 | 04:24 PM
speed racer's Avatar
Just get a new axle.
Old Jun 24, 2007 | 08:20 PM
Cdg2125's Avatar
ok thanks. I guess I'll get autozone axle. I was told that they are actually decent for the price. My axle does not click as of now but I guess I'll go that way.
knight_yyz
Nov 1, 2015 01:34 PM
uttadms31
Sep 30, 2015 05:24 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
londonflu
Sep 19, 2015 02:33 PM
