New problem from changing axles
Old Jun 29, 2007 | 11:47 AM
TriniRicanPapi's Avatar
I got my axles changed yesterday, later on that day when I got on the highway i felt a little vibration on the pedal, and when i gave it some gas i heard a very quiet rumbling noise, i called the mechanic this morning and he told me maybe my wheels need balancing but i have four new tires and the wheels have all been balanced within the year. I'm planning on taking it back to him later today to check it out. Any ideas what it could be?
Old Jun 29, 2007 | 12:01 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
Did you tighten down that bracket on the passenger side axle all the way?
Old Jun 29, 2007 | 01:35 PM
maximafrenzy's Avatar
Fuhget About It.....
Arent you supposed to get an alignment if you replace your axles?
Old Jun 29, 2007 | 01:39 PM
well i've been needing an alignment for a while now but i haven't had this problem before so i'm not sure
Old Jun 29, 2007 | 02:42 PM
CoamoMax's Avatar
Could be low on tranny fliud. Just a thought.
Old Jun 29, 2007 | 02:59 PM
mikey chalupa's Avatar
I have the same problem as the thread starter. I believe that it might be assciated with the bracket not being tight. I have one thatis tightened, but the other is kinda just hanging in there.
I don't think that being low on tranny fluid will cause vibration in the gas pedal.
Old Jun 29, 2007 | 03:05 PM
Vlasic's Avatar
so are those 3 12mm bolts that bolt the axle to the bracket on the block tight? If those are not tight that can move around and make a noise and a vibration.
Starrider
Sep 17, 2015 07:26 AM
boomerbrian
Sep 2, 2015 03:46 PM
RealityCheck
Aug 5, 2015 06:18 AM
