Changing belts 1999 Maxima TENSION
They look rough so started it myself. A little tougher then I thought. Is there any special technique to get the right tension on the belts. Using the Haynes manual seems really good.
Set the tensioner adjustment bolt hand tight until you can feel the resistance change. If the belt squeal when starting the car, tighten it quarter turn more.
After you tighten the center nut, back off the tensioner adjustment bolt a little.
Ray229Harris
Sep 16, 2015 08:16 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
Maxima2010 Prem
Aug 13, 2015 11:34 AM
RealityCheck
Aug 5, 2015 06:18 AM
