RPM signal in coil pack.. which color wire is it??
I wasn’t trying to be a buttocks. The thing is, where you obtain RPM signal depends on the RPM switch. Some require the use of the ECU wire. Some do not (Harlan). The Harlan you can use the coil wire.
The FSM will tell you which wire to tap via ECU, as well as which wire is the main signal wire re: coil pack wires which will give you the reading you want.
Frequency is a speed input/output (i.e. RPM revs PER minute) so, if you read the manual you will see that x hertz = x RPM, roughly. Turn that into an equation, and you have a nice reference and linear equation. Plug in some #'s and you have a relation. You’ll need some type of hardware &/or software to read it this way.
If you have an RPM switch, it does it for you (the conversion) and makes it sound more human like, and not geek like.
I know that a MSD 8969 RPM switch can be programmed to work from different numbers of cylinders. I use a 8969 connected to one coil trigger wire to control my MEVI, and another 8969 connected to the Tach output to shift my automatic.
? hope this helps ???
vingodine
45
May 21, 2016 12:46 PM
