View Poll Results: Three Way Catalyst code resolved by rear o2 sensor?
I currently have this code but have not replaced the o2 or visually inspected the cat
20.00%
I've had a three way catalyst function code and replacing the rear o2 sensor resolved it
10.00%
I've had a three way catalyst function code and I removed a melted cat from my car to fix it
0%
I replaced the rear o2 sensor and cat and STILL have the code
5.00%
I've never had codes P0420 or P0430 (dtc 0702 or 0703) but wanted to vote anyways
65.00%
Voters: 20. You may not vote on this poll
Three Way Catalyst Efficiency Code
Old Jul 12, 2007 | 10:11 PM
KRRZ350's Avatar
Just wondering who has had to shell out the $$ for a new cat, or who ;if anyone; had this code go away after replacing a post OR pre cat oxygen sensor........
Old Jul 12, 2007 | 10:16 PM
NmexMAX's Avatar
dot dot dot ...
0707? . . .
Old Jul 12, 2007 | 11:38 PM
maxima985spd
i voted for "I replaced the rear o2 sensor and cat and STILL have the code"
but doesnt the code have to do with the y-pipe o2 sensors?
Old Jul 13, 2007 | 05:36 AM
KRRZ350's Avatar
It has to do with all of them actually, the front o2's must rapidly change their voltage up and down (switching frequency) so that the cat will see both slightly rich and slightly lean conditions or else it won't operate properly because it needs both o2 and co to function properly, the rear o2 sensor should have a switching frequency of at least half of the front o2's. On your particular car you should have someone with a nice obdII scan tool, or you can even do it with a digital multimeter through the ecu screw and backprobing the o2 pins @ the ecu, monitor the switching frequency of the front o2 sensors to make sure it is happening at least 5 times in ten seconds and that it goes above and below a specified voltage at least once in those ten seconds.
Refer to the FSM and autoshop101.com (emissions section on closed loop control and then three way catalystfor more information and http://www.autoshop101.com/forms/h64.pdf for more info
Old Jul 13, 2007 | 08:19 AM
maxima985spd
i did back probe the right original o2 sensor using a digital voltmeter. it wasnt giving me a up and down reading like the left o2, so I replaced it with a used o2 i had laying around. now the code came back
i will use the voltmeter again...
Old Jul 13, 2007 | 11:59 AM
99BlackMaxMS's Avatar
I voted for currently having the code. It likes to pop up every 1000 miles or so and will come and go as it pleases. It clears when I clear it and when I leave it it goes away after a hundred miles. Could by my fuxed up ECU tho.....
Old Jul 20, 2007 | 12:03 PM
ThurzNite's Avatar
I have a bad coil, causing misfire. On acceleration, the MIL blinks, indicating 3way cat is being damaged. However, no other codes. Hope I didn't mess it up.
Jae
Old Jul 20, 2007 | 02:11 PM
If you drive long enough while your car is misfiring (badly enough for the SES light to flash) you can be doing some damage to the 02 sensors and the cat.
Old Jul 20, 2007 | 02:15 PM
ThurzNite's Avatar
Yeah, exhaust smells of gas.
Jae
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
