speedo working when it wants to
Old Jul 13, 2007 | 10:10 PM
nismo-max500's Avatar
My Speedometer has decided to work when it wants to. Sometimes it drops to zero for minutes at a time, then goes back to normal, than quits. Very random and it interferes with my cruise control as well.
whats goin on here?
Old Jul 13, 2007 | 10:49 PM
maxpeed96plat.'s Avatar
check ur speed sensor on ur transaxle and use stickies 4 more info.
Old Jul 14, 2007 | 12:06 AM
midnight0045's Avatar
had the exact same problem.. its not the speed sensor.. (replaced mine did the same problem.. save your money) i had to replace the whole speedometer cluster .. junkyards are our friends.. if you can't do that then.. attempt to tighten each screw on the back of the gauge cluster.. perhaps that will work for you
cheers
Old Jul 14, 2007 | 06:31 AM
99BlackMaxMS's Avatar
Vehicle Speed Sensor, or like midnight said it could be your entire cluster. Does your odometer work? If it does then it is your VSS. If not its most likely the cluster.
Old Jul 14, 2007 | 10:30 PM
maxprivate's Avatar
Black Lion
had the same problem,turned out to be the speedo head. got a new one through courtesy nissan and they calibrate your milage for you as well. and its cake to change out yourself.
mvm062
Nov 30, 2020 09:00 AM
kmitchel
Oct 30, 2015 10:12 AM
Maxima30
Sep 7, 2015 06:13 PM
iflexsteel
Sep 2, 2015 08:04 AM
Hailstatejig
Sep 2, 2015 06:52 AM
