Speaker whining noise
Old Jul 19, 2007 | 07:01 AM
GarciaMaxima's Avatar
I have after market: head unit, amp and speakers. How can I narrow down the source of the whining noise? I've had this after market setup before with no whining noise but now the whining noise is there. HELP
Old Jul 19, 2007 | 07:03 AM
Jamaha80
Whining through the speakers usually indicates a bad/weak ground. Check the ground for your amp- make sure its bolted to unpainted metal.
Old Jul 19, 2007 | 07:07 AM
Thank you. I did try that but no luck. maybe I will try grounding it somewhere else.
Old Jul 19, 2007 | 07:23 AM
TunerMaxima3000's Avatar
did you wire it up yourself? Make sure your RCA's are isolated from all other wiring, and your speaker wire away from power cords as well, that is the main cause of whining, check your grounds as well as mentioned, keep them as short as possible (18" is spec dont go much more than that)
Old Jul 19, 2007 | 07:31 AM
99grnmaxgxe's Avatar
A good ground is one of the bolts holding down your seat beat I believe.
Old Jul 19, 2007 | 08:31 AM
WhiteA32's Avatar
Make sure you go a good job sanding around your ground point.
Old Jul 19, 2007 | 08:50 AM
andrei3333's Avatar
does it happen when ur cell rings ? or all the time
Old Jul 19, 2007 | 09:16 AM
thanks for all the suggestions. The whining noise is at all times and when my cell rings
Old Jul 19, 2007 | 09:22 AM
andrei3333's Avatar
then thats the wiring, something is either not grounded properly, or stripped wires are picking up interference
Old Jul 19, 2007 | 09:54 AM
actually I meant NOT when my cell rings, the whining is on all the time. It gets louder when I accelerate
Old Jul 19, 2007 | 12:29 PM
heynow's Avatar
bad ground somewhere/power wires too close to speaker wires/exposed wires/bad connection
Old Jul 19, 2007 | 07:24 PM
if the amps in the trunk ground it to one of the wheel well lower corners, that where the most meat is. also like I said short as possible, and same guage as your power wire, but check your RCA's first.
Old Jul 20, 2007 | 02:23 PM
Problem found
apparently the source of the whining noise was a faulty headunit, I got my headunit replaced and whining noise is gone. I guess when my amp shorted out, it damaged my headunit.
Thanks for all those who helped.
Old Jul 24, 2007 | 10:51 AM
T_Dwyer88's Avatar
What system do you currently have in your car
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
magiconthetire
Oct 26, 2015 09:03 PM
uttadms31
Sep 30, 2015 05:24 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
