cold air intake questions
Old Jul 18, 2001 | 11:12 PM
jay_johnson's Avatar
What is a good cold air system for a 95 max. I'm looking in the $150 range. i did the brianv mod and now i'm hooked. I need a little help on selection and on install.
Old Jul 18, 2001 | 11:34 PM
1/3There2/3ToGo's Avatar
For $150 I dont know what there is. If you can muster up $220 go to www.cattman.com and get the Place Racing CAI. I just put mine on and it is WONDERFUL! You will definatley feel the power gain. In a '95(which I also drive) you will notice about at 7-9 hp gain and about 17-20 lb/ft of torque. This is one of the best mods you can get if you are just starting out. Under WOT(Wide Open Throttle) it sounds like you have a small block V-8 under your hood.
K
Old Jul 19, 2001 | 12:21 AM
SkylineGTR's Avatar
torque?
17-20 lbs of torque....i dun think so....the hp number si about right but no way the prcai give 17-20 torque. ill believe that when i see a dyno....not trying to sound offensive but just saying
Old Jul 19, 2001 | 12:29 AM
Re: torque?
I could be off on that #, but it FEELS like that much. I can spin the wheels much easier off the line than before, there must be a substantial torque gain with it.
K
Old Jul 19, 2001 | 12:37 AM
What kind of installation is required? Could i do it myself? I know $150 sounded stupid... I've been looking for a long time now and i noticed how off that was.
Old Jul 19, 2001 | 12:48 AM
The install is pretty easy. The PR CAI comes with instructions that are sufficient. You will need a hole saw(I forgot the size, 3.5" I think). All you do is take off all the stock intake stuff and you need to take out the battery and its brackets. Then you drill the hole. Next is the install of the part of the intake the goes directly into the engine, then the other connecting pipe. Then you take off the front part of your splash guard and put on the filter. Put the splash guard back on along with the battery and your ready to rev up the beautiful new intake.
K
Old Jul 19, 2001 | 06:47 AM
breaux124's Avatar
Cattman has a special on the CAI, it's $200.
But I'm pretty sure it's not place racing's anymore. He now makes and sells his own CAI, but it the same thing.
Old Jul 19, 2001 | 09:11 AM
I still don't understand. I know that the whole idea is to bring air from outside of the engine, but where does the filter go. Is it outside of the engine? This seems awfully strange. Somebody please give me a detailed install so I can understand this further.
Old Jul 19, 2001 | 09:13 AM
breaux124's Avatar
www.maximadriver.com
Under the how to section
And yes the filter is outside of the engine, if you look under the hood, you cut a hole into the fender wall right behind the battery. The filter hides in the chamber that is behind the plastic of the wheel well
Old Jul 19, 2001 | 10:56 AM
SuDZ's Avatar
On Intake cuts
I know that when you go for something like the CAI you have to make a hole in the side. Thats the part tht scares me. How big of a hole do you make and how much danger is there in cutting or damaging the outside of the car. Also is it just a regular saw type equipment you can use or do you need something more powerfull / special to do this job? Do they make one where you would not have to cut anything?
SuDZ
Old Jul 19, 2001 | 11:08 AM
breaux124's Avatar
Re: On Intake cuts
SuDZ
The hole is about 2.5 inches wide.
Use a hole saw, it'll make your life much easier.
Old Jul 19, 2001 | 11:29 AM
Dan 93 SE's Avatar
CAI
Check our our prices. They are listed on our web page WarpSpeedPerformance.com
Dan WSP
Old Jul 20, 2001 | 03:22 AM
How does the warpspeedperformance.com cai compare to the place racing cai in terms of performance?? The price makes me think that it is very large.
Old Jul 20, 2001 | 05:15 AM
Dan 93 SE's Avatar
WSP CAI
If you put them side by side, hard to tell the difference. Both 3" mandrel bent, theirs has a K&N filter, ours has a no name brand. You can purchase ours without the filter if you really want the K&N filter, we believe that ours performans every bit as well as the PR model.We have personally dyno tested our Y-pipes and posted results. Few believed us, so we now have several Maxima.org members getting there cars dynod with them and THEY will post results. One of the main reasons Dallas and I started making aftermarket mods was we were tired of paying too much for them. It's the USA, buy what you want, pay more if you want to.
Dan WSP
95Maxi
Aug 29, 2015 09:38 PM
bc992164
Aug 26, 2015 12:19 PM
cheftoo
Aug 20, 2015 05:17 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
