HELP!! car wont let me shift!!
Old Jul 26, 2007 | 09:30 PM
maximarozin's Avatar
I was doing the shift **** mod by ptatohed and i accidently dropped one of the screws from the new **** assembly into the pole that holds the skinny bar and now its preventing me from shifting.
I was wondering what the best thing to do would be in the situation?
Also, is it alot of work to remove the rod to get to the screw and does anyone have instruction on how to do it?
I would really appreciate some help on the matter.
From anyone.
Thanks,
Old Jul 26, 2007 | 10:01 PM
WhiteA32's Avatar
Why not try to remove the screw, your prolly going to have to remove the whole shifter assembly to get to it...
Good luck...
Old Jul 26, 2007 | 10:05 PM
maxima985spd
shift **** mod
say that 5 times fast
shift **** mod shift **** mod shift **** mod shift **** mod shift **** mod
Old Jul 27, 2007 | 07:10 AM
Good luck...
i figured that, but i couldn't find instruction on how to do that.
is it alot of work to do that, do i have to go under the car to remove it?
Old Jul 27, 2007 | 07:28 AM
vuiskool's Avatar
is it visible? Go get a antenna magnet and get it out?
Old Jul 27, 2007 | 07:58 AM
it is not visible and is stuck very tightly.
Old Jul 27, 2007 | 08:19 AM
MaxFanatik's Avatar
thats not cool, and u dont got much room to play with there, i would get a long screw driver and try knock it loose up and get a one of those skinny attenna magnets, and than start poking and praying.
Old Jul 27, 2007 | 10:36 AM
does anyone know how to remove the shift rod from my car?
Old Jul 27, 2007 | 05:39 PM
so i went to a mechanic and he quoted me 400$ to replace the shift assembly.
He said he couldn't get the screw out.
Any thoughts?
Old Jul 27, 2007 | 10:41 PM
maxpeed96plat.'s Avatar
Fish it out, if it got in there it will definitely come out unless u keep grinding it in by shifting. Do wat MaxFanatik said.
Old Jul 27, 2007 | 10:51 PM
hybridc24k's Avatar
try the magnet. it usually works
Old Jul 28, 2007 | 12:36 AM
maxima985spd
I don't see how it could of gotten stuck. start removing bolts/nuts until it's removed. then fish out the bolt
Old Jul 28, 2007 | 06:14 AM
the_3d_man's Avatar
get a high strength magnet and stick it to the shift linkage by the tranny and work it up to the shifter until the screw falls out?
Old Jul 28, 2007 | 09:44 AM
Snypa's Avatar
try turning the car upside down(j/k)....try using the magnet man, we all said it,can u even see it at all, if so thats good, if not, put something down there and start playing with it.
Old Jul 28, 2007 | 01:36 PM
the magnet doesnt work
Old Jul 28, 2007 | 01:42 PM
Snypa's Avatar
hmmmm.can u see the screw at all.?(startin to sound serious)
Old Jul 28, 2007 | 02:28 PM
yeah, but its all the way at the bottom
Old Jul 28, 2007 | 02:46 PM
EnervinE's Avatar
i has college
Magnetize two pieces of clothes hanger wire and start fishing.
Old Jul 28, 2007 | 05:51 PM
wiggafly808's Avatar
Try and knock it loose first, or the magnet wont be strong enough to pull it up.
Old Jul 28, 2007 | 06:10 PM
enough with the magnets, i mean thanks but i tried the magnet a million ways,
Old Jul 28, 2007 | 07:03 PM
Gun5's Avatar
well a shifter assembly is cheaper then 400 bucks so start prying the **** out of it the worst u can do is buy another but i doubt ur gonna **** it up
Old Jul 28, 2007 | 08:27 PM
ok so i fixed it by cutting out the piece of the rod i thought the screw was at and thankfully i was right about the position of it,
Lakersallday24
Jun 16, 2019 01:35 AM
maxinout93
Oct 27, 2015 01:29 PM
jhontelj
Aug 17, 2015 04:07 AM
Trin1j23
Aug 12, 2015 08:31 PM
