Noise won't go AWAY!!! woot woot woot woot :(
Old Jul 31, 2007 | 04:34 AM
Kevlo911's Avatar
Kevlo for President
SO, 2 days ago my car started making this woot woot woot woot woot sound that increases as I speed up. The only time it stops is if I turn the wheel slightly towards the right, if I turn it slightly left the noise is still there but the pitch changes.
Other things to note, doesn't matter how fast I am revving, noise happens in all gears. Happens in neutral and it doesn't matter if the clutch is pressed in or not.
Doesn't stop when I hit the brakes either...
I inspected it with the wheel on and nothing seems out of the ordinary. As far as I can tell the noise is happening from both sides but I have no idea what it could be since the noise does not stop when I hit the brake or the other things above. What baffles me is that the noise stops when I turn the steering wheel to the right
So what should I be looking at...
Old Jul 31, 2007 | 04:56 AM
scrhale's Avatar
It is because your are a UF fan! JK. Just out of a random but probably incorrect guess, could it be your PS belt maybe getting lose or freying?
Old Jul 31, 2007 | 05:14 AM
sagamax's Avatar
Give me a Bud Light Holmes
maybe some of the plastic inside the fender is out of place and rubbing on the tire.
Old Jul 31, 2007 | 05:23 AM
skuccio's max's Avatar
Beast Mode!!!
Sounds like a PS belt...
SEARCH!!!
Old Jul 31, 2007 | 05:33 AM
Kevlo911's Avatar
Kevlo for President
It does NOT increase with the revs only with speed so how could it be engine related?
I checked for splash guard rubbing but I could not see anything.
Old Jul 31, 2007 | 06:06 AM
XJinCT's Avatar
<3's the all motor section
check wheel bearings for play. (shake wheels left and right, up and down)
Old Jul 31, 2007 | 06:27 AM
Kevlo911's Avatar
Kevlo for President
That's what I was thinking but how could it explain the noise stopping when I turn the wheel SLIGHTLY to the right?
Old Jul 31, 2007 | 07:17 AM
heynow's Avatar
I guess the brearing is so loose that even turning the wheel would affect it. Check for play.
Old Jul 31, 2007 | 07:19 AM
mtrai760's Avatar
'Trynna' is not a word
If you cannot find anything rubbing, I would suspect a wheel bearing.
Old Jul 31, 2007 | 07:21 AM
97SEdriver's Avatar
this place is dead
Kev....you got that big brake kit right?.......
Old Jul 31, 2007 | 07:30 AM
97SEdriver's Avatar
this place is dead
http://forums.maxima.org/showthread.php?t=527687
Old Jul 31, 2007 | 07:58 AM
JtzMax's Avatar
Whatchyou say?
Originally Posted by 97SEdriver
FTMFW !?!?!
I would have thought bearing too ... but now after reading this thread ... I dunno. You may still check the wheel bearing as well ... may be some play in it.
I had an old Supra that I had to repack the front wheel bearings on at least once a year if not twice. It's a pain, but a job that can easily be done yourself as long as you can jack the car up enough to remove the tire and pull the hub assemb off.
If you find it is your bearing, you can fix the problem for under $5 -- http://www.absolutehome.com/web/cata...D1D389BC52DB41
Dunno if you have ever repacked bearings, but it's easy as eating pie. PM if you need any help ... if you find this is the prob.
Cheers mate!
Old Jul 31, 2007 | 08:01 AM
WhiteA32's Avatar
Kevlo this happen to me after I changed my axles.
It was the axle nut. It wasn't tighten down properly, which made the wheel not stay straight.
So before you change your wheel bearings check the axle nut
Old Jul 31, 2007 | 08:22 AM
Allens96SE's Avatar
I'd suspect wheel bearing / axle nut as well, but is anyone else thinking.... CV joint?? To see if the CV's are bad check the rubber boots for cracking - if they're cracked & all the grease is gone and you need a new CV joint.
Old Jul 31, 2007 | 09:24 AM
Kevlo911's Avatar
Kevlo for President
Fixed it long ago, like I said, hitting the brakes doesn't change the noise. So I guess wheel bearing test later today...
Old Jul 31, 2007 | 09:26 AM
Kevlo911's Avatar
Kevlo for President
Brand new CV joints, Raxle on drivers side and advanced auto on pass side. Boots are fine.
I pulled on the axle so I don't think the nut is loose and I put them on with air tools so they are very tight. But I will try to check this weekend or I will see if I can pop the center cap off and see it.
Old Jul 31, 2007 | 10:25 AM
MaxGordon7's Avatar
axles have to be on at 250ft/lbs, most impacts wont put on the much pressure unless its a hella nice one.
Old Jul 31, 2007 | 03:35 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
Lift the car up, put it on jack stands- have someone drive it in the air with the wheels off the ground.
Use a LONG screwdriver or a s***hoscope to listen to where the noise is coming from. Check everything including the tranny.
Old Jul 31, 2007 | 03:57 PM
maxima985spd
if there is only slight play in the axle nut you will hear a noise. I think you need to tighten your axle nut.
Old Jul 31, 2007 | 04:16 PM
Dan_E_Boi84's Avatar
You probally wont have play if it's a wheel bearing. Fourth gen bearings are sealed. It definitely sounds like a wheel bearing. The reason why you hear more noise when you turn is because of the transfer of load. When you turn right the weight shifts to the left of the car and is more concentrated on the left front wheel. So what happens is the worn bearing is stressed more causing more noise. Think about a cart on rough cement. The more wieght thats on the cart the more noise it makes as it rolls. You have a bad front left wheel bearing. Whats gotta happen is you've got to take the whole hub off and press the bearing out. The bearing is 35 bucks at autozone and it'll be best if you take it to a shop to have them use there press to do the work. Good luck with it bud. It cost me 210 to have mine replaced.
Old Jul 31, 2007 | 10:07 PM
Kevlo911's Avatar
Kevlo for President
First I will check the axle nut this weekend and go from there(gonna try and see if I can tell it's loose from the wheel center cap first).
I can't test anything else until after finals which will be at the end of next week, 4 tests in 5 days
Old Jul 31, 2007 | 10:20 PM
maxima985spd
Use a long breaker bar to tighten the nut by hand. You will know when it's tight, you won't be able to turn it all any more.
Old Aug 1, 2007 | 05:13 AM
97SEdriver's Avatar
this place is dead
Kevlo don't need no Breaker Bar
Old Aug 1, 2007 | 06:35 AM
Kevlo911's Avatar
Kevlo for President
Lol yeah, I know how to install axles. After all, I just converted the car from auto to manual a few weeks ago...
Old Aug 1, 2007 | 07:18 AM
G4nismo's Avatar
omg everytime, i hear someone that has done that, makes me soooo angry!!!
i would do anything for that conversion! just curious how much did it cost you and time if you don't mind.
Old Aug 1, 2007 | 07:24 AM
Kevlo911's Avatar
Kevlo for President
I will post a thread on it soon with pics and such. It took me 6 hours
Anyways, Axle nuts are nice and tight so that leaves me to test the wheel bearings.
Old Aug 1, 2007 | 08:17 AM
MorpheusZero's Avatar
O
M
G
Best post EVAR.
Kev, first thing I thought of was the brakes as well. If all else fails... I'd probably revisit the grinder.
Wheel bearing test is eassyyy, hurry up.
Old Aug 1, 2007 | 09:10 AM
Kevlo911's Avatar
Kevlo for President
Not the brakes, different from that noise, that noise would stop when I hit the brakes, this has a different tone to it. Wheel bearing test will come on fri, now I have to hit the books
Old Aug 1, 2007 | 02:57 PM
97SEdriver's Avatar
this place is dead
my post was awesome......just to let you know.......
Old Aug 1, 2007 | 08:57 PM
Kevlo911's Avatar
Kevlo for President
It twas, I agree
Old Aug 2, 2007 | 09:13 AM
G4nismo's Avatar
It took me 6 hours
WHAT!? 6 hours my white ****
Old Aug 2, 2007 | 12:54 PM
ThurzNite's Avatar
I vote for bearing/hub. Just as posted above, even when the bearing goes bad, i didn't get any excessive play in the wheel. It wasn't until steering felt loose and brake pedal acting up that I took out the axle, inspected the bearing/hub, and found it dead.
You can try driving alongside a wall to amplify the noise.
Jae
Old Aug 2, 2007 | 01:19 PM
Joshua8's Avatar
If the noise appears at 40-50 mph and speeds up with increased speed I'm betting bearing..
other than that who knows?
Old Aug 2, 2007 | 08:57 PM
The wheel bearing can make a noise at 15 mph and greater... I'm betting $20 it's a wheel bearing...all those that say it's not my paypal account is ready for ya.
Old Aug 11, 2007 | 08:13 AM
Kevlo911's Avatar
Kevlo for President
Just did the tests, noise is louder in the car than outside(might be due to engine noise outside). Pass side hub area is where the noise is from. I did the "up/down----left/right" wheel shake test and it failed. Drivers side is nice and tight but pass side wobbles like no other.
Now I am to buy another NTN(nissan) bearing from rockauto.com, should I replace the oil seals as well?
Old Aug 11, 2007 | 01:21 PM
Kevlo911's Avatar
Kevlo for President
Bought 2 oil seals(oem) and 1 bearing(oem) for 53.67 shipped from rockauto
Old Aug 11, 2007 | 04:26 PM
silverdustmaxim's Avatar
good price, and smart decision on getting the seals. i just did my left front last week, my right front last year and both times i had to replace the hub as well. the bearing race is pressed onto the hub and when the bearing fails , after a little time the race begins to spin on the hub. expect to be ordering a hub, but you may be lucky.
Old Aug 11, 2007 | 04:35 PM
Kevlo911's Avatar
Kevlo for President
Been less than 400 miles so I hope not
Old Aug 12, 2007 | 01:03 AM
ThurzNite's Avatar
Yeah, I got seals w/mine too... did the hub cuz that thing was messed up.
Jae
Old Aug 22, 2007 | 09:48 PM
jpn's Avatar
jpn
great thread i have the same prob i just did my axle and theres still the noise so im thinking it could b that
