Wonna rewire my fogs
Old Aug 2, 2007 | 07:05 PM
wirelessdude04's Avatar
Few questions... When I cut the fog relay which part do I connect to the wire im adding?? The part still connected to the relay or the peice i cut off?? Also what type of wire should I use to connect the relay to the bumper lights?? Using this as my reference http://www.vqpower.com/v2/readarticle.php?article_id=31
Old Aug 3, 2007 | 12:49 AM
markd248's Avatar
Connect the new wire to the relay side wire it says it in the write up
"You want to cut this wire, make sure to leave yourself enough wire on the relay side of the wire to splice into. Once the wire is cut, tape off the +12V wire with electrical tape (this is the half of the wire that isn't attached to the relay)"
As for the wire I used a 12 or 14 guage wire, it was way too big so i recommend something much thinner than that. Hopefully someone knows the exact size of the OEM wire.
Old Aug 3, 2007 | 03:40 AM
alright cool ill try some 8 guage maybe... Thanks
Old Aug 3, 2007 | 03:42 AM
oh btw when im connected it do i need a postive and neg wire? Or what.... Cause when Im connecting it to my fogs istn there a red blue and a red wire or maybe a black for ground?
Old Aug 3, 2007 | 09:13 AM
Digitized's Avatar
you don't need to reground..
what you are doing is your are getting the power from another source...
I did this in a matter of 20 minutes... the longest part was getting getting the fuse box to seperate from each other ( top and bottom part)..
Old Aug 3, 2007 | 12:24 PM
how many guage should the wire be?
Old Aug 3, 2007 | 09:23 PM
95pearl's Avatar
deffinately the longest part of the whole install
Old Aug 4, 2007 | 07:21 AM
did it last night will post pics when I get a chance pretty simple lol first it didnt work i was like wtf then lol i was like where the hell are the relays worked great.. Thanks guys now to fit these is300 capsules in my fogs
Old Aug 6, 2007 | 11:06 PM
markd248's Avatar
Yeah I want to retro my fogs as well. The fog rewire is a straigt forward install and very easy hope everything worked out well.
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
Calabar
Oct 5, 2015 09:57 PM
