Door Open Light?
Door Open Light?
Since saturday, my door light goes on randomly and flciekrs or stays on. I noticed it stays on more when i kepe it over 75mph...... can some one tell me if there is a fuse for it, if so ill just pull it
Well there is a fuse but it cuts out all interior lighting. Sounds like the switch contacts might be worn. Theres a little push style switch where the door closes. check that. if not. pop the lense off the light and just pull the bulb out it its bothering you.
well even if i pull the bulb of the dash board, the lights at the sides of my door still light up!!!!! =[ juss annoying. i opened the drivers door the rubber part of it is all gone but the button pushes in fine... so i dunno
Wait. I didnt get that before.. Is it all the door interior lights?
If so then it the switch garanteed. theres not to many factors involved with that circuit
Im not sure if its stuck. remember the max is an old car. Ive seen some crazy old circuitry in this car. It might be the physical contacts inside the switch are just bent/worn out
Pull it off and check it out,.
rusted door open switches.
i heard of this and replaced the rubber covering with new ones. my old ones were worn and had holes in them. basically pull the switch and spray it with some anti rust spray, and see of that helps, if not then get one working switch and test all 4 doors by replacing the switch...
Originally Posted by EnervinE
I don't think those can go bad unless they've actually been messed with/exposed to hazardous conditions...my car's been daily driven for 10 years and mine look brand new.
My max is not from NJ.. orignally Virginia....
My switches doint look rusted.........
now i noticed on hard rite hand turns that thing turns on, im starting to think its my passenger rear door on the driver side, its been hit there and w/e did the body work did a crapola job so it doesnt close as tight.
okay this thing is pising me off at nite, it jsut ligths up and doors light up...
turns on when:
Making right hand turn
going on bumps
Flucttuates the blinking to my exhaust or my bass of my music
turns off:
making a left hand turn
or reopen and close door.
how can i disengage the whole damn system like cut a power wire to the main soure?
turns on when:
going on bumps
turns off:
I kinda had a similar problem. My problem was the screw was loose where the door switches are, so I took a screwdriver and tightened them. The switches were loose giving off the signal that the door was open.
The bulbs on the door panels are also easily accessible.
vingodine
45
05-21-2016 12:46 PM
King_Ten_Ahead
09-30-2015 04:27 PM
