Lower bolt on Starter (with pictures)
Old Aug 7, 2007 | 08:17 AM
schreiber117's Avatar
see http://forums.maxima.org/showthread....27#post5872527 for pictures
Just curious if someone has a trick for this bolt, I could not budge it last night...
no way to get leverage... if I have the three inch extension on (which dropped later to G-d knows where, yay!!!) the wrench cant swing because of stuff behind it, and without the extension it cant swing because of the hoses and wires. I know a lot of people have changed their own starter.. any help would be appreciated
I've worked on Subarus and Hondas before this, I have to say, easy access to DIY repairs, Nissan FTL
Old Aug 7, 2007 | 08:23 AM
gen4maxima536's Avatar
breaker bar, pb breaker and probably an extension.
last time i did it i think i had the breaker bar in between the wiring for the abs pump and just got it to budge enough so i didn't pulling on the wiring harness, and so i could reposition the bar.
Old Aug 7, 2007 | 08:28 AM
pb breaker??
Old Aug 7, 2007 | 08:33 AM
KRRZ350's Avatar
1/2" drive and a jack handle FTMFW. He meant pb blaster, but don't even bother, on a bolt like that it won't help and if anything will do more harm than good if the bolt head is covered in oil.........
Old Aug 7, 2007 | 08:51 AM
1/2" um, 17mm no?
Old Aug 7, 2007 | 11:27 AM
ObsidianIce69's Avatar
^ 1/2" drive refers to the breaker bar basically, i don't think that was a 17mm bolt either. I seem to remember it being smaller when i changed my starter but i could be wrong.
Old Aug 7, 2007 | 12:52 PM
It is definitely a 17mm bolt... I'm going to pick up a pipe to use as a breaker bar on the way home.. any other suggestions?
Old Aug 8, 2007 | 10:05 AM
Peebs187's Avatar
PB Blaster does work, especially if you give it a day or so of dwell time. Grab your 3/8" or 1/2" ratchet, bring it to the hardware store, find a piece of steel pipe that fits well, buy 5 ft. then make a few different lengths of pipe. Now you have some options for the next time you need some... old man strength.
A jack and jack stands are your best bet. I beleive the bolt is easily accessible from underneath. $60 to $100 or so at Sears, it's something you will use for the rest of your life.
Old Aug 8, 2007 | 10:13 AM
Picked up 2ft piece of pipe last night... BREAKER BAR FOR THE FTMFW... now I have other problems...
http://forums.maxima.org/showthread....=1#post5874853
Issue is resolved if you want to close this out
Old Aug 8, 2007 | 01:43 PM
ThurzNite's Avatar
Wait till you get to an axle nut that need to be removed.
Jae
Old Aug 8, 2007 | 01:46 PM
If my car ever runs again, I'll make sure to note that..
see
lowpost99
Oct 26, 2025 06:53 PM
Starrider
Dec 18, 2015 04:43 AM
dcam0326
Sep 18, 2015 04:52 PM
doctorpullit
Sep 10, 2015 06:33 PM
Violator
Sep 9, 2015 10:14 AM
