code 0308
Old Aug 12, 2007 | 03:18 PM
Xzecution'R's Avatar
code 0308
i keep gettin this code so i replaced my front right O2 sensor and it's still there. my car does not feel or sound like it's misfiring help please.
Old Aug 12, 2007 | 08:32 PM
67whitegoat's Avatar
p0308?....8? What year is your car?
Old Aug 12, 2007 | 08:45 PM
95 se. just 0308 i did the ecu screw thing.
Old Aug 14, 2007 | 08:12 PM
are the 2 white wires on the o2 sensors interchangable?? maybe that's my problem...
Old Aug 14, 2007 | 08:50 PM
lexoid's Avatar
The white wires are interchangeable. With the engine warmed up, maintaining engine speed aroung 2000 rpms, you should get voltage between white wire and chassis ground which periodically changes from 0v->1v->0v so on. Minimum should be 0-0.3v, max: 0.6v-1v. Get the FSM for more details.
Old Aug 14, 2007 | 09:33 PM
Kevlo911's Avatar
Kevlo for President
Did you reset the ecu?
Old Aug 15, 2007 | 10:20 PM
yes i did.
Old Aug 18, 2007 | 12:05 AM
so after a week of city driving i didn't have it and 2 mins on the hwy and my buddy cel light comes on witht he same code again
Old Sep 1, 2007 | 01:51 AM
does any1 know where this module is or where the wires and plug(s) are located it only comes on when i'm on the hwy but driving in the city i'm fine.
0308
Diagnostic Trouble Code 0308 points to a problem with the Engine Control Module Closed Loop Logic for the Right Bank. The right cylinder bank is also called the rear bank. It is cylinders 1,3,5.
DTC 0308 is detected when the closed loop control function for the right bank does not operate even when the vehicle conditions meet the criteria (engine at normal operating temperature, etc.). Possible causes include ...
- Harness or connectors (The sensor circuit is open or shorted.)
- a defective Front Heated Oxygen Sensor sensing element.
- a defective Front Heated Oxygen Sensor heater.
Old Sep 1, 2007 | 05:45 AM
Kevlo911's Avatar
Kevlo for President
Test the circuit
Old Sep 1, 2007 | 09:19 AM
benalcoa's Avatar
Yeah, test the circuit.
Old Sep 1, 2007 | 12:19 PM
the O2 wiring u mean?
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
