Adjust trunk???
Old Aug 16, 2007 | 05:41 AM
Toolatecrew's Avatar
Adjust trunk???
My 99 GLE has a rattle coming from the trunk area only over sharp impacts . I discovered that the little clip that holds then torsion rods in place was broken and replaced it and it did improve it but it still happens occasionally. It's hard to know for sure without getting into the trunk while someone drives but it seems to be either the trunk itself moving or the bracket that holds the rods /rods rattling.
Anyone know how I can adjust the rods or get the trunk to close more securely (tighten it down) to see if that fixes the issue? I've tried the search and come up empty.
Old Aug 16, 2007 | 07:33 AM
xsnowpig's Avatar
spolier? mine rattles cuz i snapped the outside plastic clips.
Old Aug 16, 2007 | 08:16 AM
Nope no spoiler.
Its is for sure nothing outside. I'm fairly certain its to do with the trunk lid itself or those stupid torsion rods/brackets.
Old Aug 16, 2007 | 08:42 AM
Fast1one's Avatar
Adjust the latch via two 10mm (I think?) bolts on the back wall of the trunk, not the lid itself but at the bottom...You will see it.
Loosen it and lower it as low as possible. Be sure the two bolts remain fairly perpendicular to the ground so the trunk still closes evenly, hope this helps
Old Aug 16, 2007 | 09:36 AM
BLACKonBLACK98's Avatar
Former Vendor
i don't think the rods are adjustable short of bending, and without knowing whats wrong that wouldn't work. adjust the latch like above, or the lid itself. check out your weather stripping too.
Old Aug 16, 2007 | 10:36 AM
tried that. Still didn't fix it but at least now I know.
Old Aug 16, 2007 | 10:38 AM
I adjusted the latch. How do you adjust the lid itself? Are their bolts?
The car is 8 years old so the weather stripping may have lost some of its cushioning I'll take a closer look.
Old Aug 16, 2007 | 04:17 PM
nhaven's Avatar
I had rattles coming from the rear of the car that drove me nuts for months. Turned out to be the headliner. One of the clips came off.
Just go back there and gently tap on the headliner. You'll hear it, if one of the clips is loosed or came off all together.
Old Aug 16, 2007 | 05:15 PM
MOHFpro90's Avatar
Try having someone poke around, push on things, etc...while driving. Maybe not in the trunk(unless you used a pole, or something through the seat opening), but that will give you an idea of where/what it might be. Also, check your speaker covers, and the light switch cover.
Old Aug 17, 2007 | 07:57 AM
Former Vendor
you can adjust the trunk via 4 10mm bolts on the bottom side of the lid, my cars been in pices so long i forget if theres something covering it, probably a carpeted liner.
Old Aug 17, 2007 | 08:07 AM
WhiteA32's Avatar
Are you sure its your torsion bars?
I know when I first got my car it was the 2 peice tools to my stock jack that was dancing around in the spare wheel well...
Old Aug 17, 2007 | 09:01 AM
Former Vendor
have you tried taking everything out of your trunk?
Old Oct 16, 2011 | 11:47 AM
rayinm's Avatar
Lol ^^^ that does actually help
Old Oct 16, 2011 | 01:00 PM
GGENIUS's Avatar
i have a rattle in my trunk, because i dropped a ****ing washer down into the decklid. it went in the hole thats there under the liner for taking the spoiler out. it fell down into some tiny *** ****in space.
REDinLV
Aug 15, 2024 12:30 AM
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
leatherneck
Sep 30, 2015 09:16 PM
