popping noise when pumping brakes???
Old Aug 16, 2007 | 12:05 PM
jvckustumz's Avatar
okay whenever i pull up to the garage or a store and i puch the brake going like 1 mph my front dr. side wheel pops, its only a noise and it only does it when i first push the brakes or if i was to pump the brakes it would pop everytime i pushed in the pedal, i have all new balljoints and all the bushings are new polyeuothane except the lower control arm bushing, i never got around to putting it in, can someone help???
Old Aug 16, 2007 | 11:19 PM
maxpeed96plat.'s Avatar
check ur piston to make sure it's not leaking or sticking other than that dunno.
Old Aug 17, 2007 | 04:08 AM
Fasteddie01's Avatar
Also, you might check caliper attachment bolts and lug nuts. Sounds like something loose ?
Old Aug 17, 2007 | 04:14 AM
Maxima_Joe's Avatar
4th Gen Parts King
Sounds like wheal bearing. Or the axle nut is loose.
Old Aug 17, 2007 | 10:11 PM
free search wheel bearing check, the axle nut is self explained.
Old Aug 22, 2007 | 05:55 PM
Maxima_Joe's Avatar
4th Gen Parts King
You ever find the problem?
BkGreen97
Apr 2, 2016 05:47 AM
Excalibur23
Oct 13, 2015 04:33 PM
RWCreative
Sep 21, 2015 11:01 AM
lrb6805
Sep 17, 2015 04:49 PM
thenewguyy
Sep 12, 2015 11:12 AM
