Parking Brake Mechanism siezed - any ideas ?
Old Aug 19, 2007 | 02:07 PM
Kevin's Avatar
Hey all,
just got through a rear brake job and I noticed that my parking brake mechanism is somewhat siezed. THe part that is attached to the spring clip that releases the brake caliper when you let down the parking brake doesn't release when the brake off. I tried soaking it in WD-40 but still no luck. I can rotate it back and forth with a wrench, but it doesn't rotate freely by itself and is seems that the spring clip doesnt force it back when you release the brake. Is there a way to replace just that part of the brake caliper ? or am I looking at a new caliper ?
Old Aug 19, 2007 | 02:20 PM
Keatz's Avatar
I had that same problem and thought it was the spring, replaced the calipers and it somewhat solved the problem for about 3 days and even then it was not fulling releasing. Then i replaced the handbrake cable and that solved it.
Old Aug 19, 2007 | 02:44 PM
Kevin's Avatar
thanks for the info, how hard was it to replace the cable ?
Old Aug 21, 2007 | 12:32 PM
phenryiv1's Avatar
Mod her. Ate her.
I did not think that you still had the A32. Sorry I cannot help- free bump for an OG...
Old Aug 22, 2007 | 08:34 AM
Kevin's Avatar
Thanks man, That car will be driven into the ground, 187k miles and running strong just gotta fix the parking brake now.
Old Aug 22, 2007 | 08:42 AM
Keatz's Avatar
I got a local shop to replace it for me for 40 bucks. Its not that hard to do if you can get underneath the car comfortably, its just removing bolts and replacing the cable and putting the bolts back in (from what i saw when they were replacing it).
Old Aug 24, 2007 | 07:08 PM
Scruit's Avatar
U wanna try me young boy?
Does the cable need to be replaced? Or can you remove it and run some lubricant through it?
Old Aug 29, 2007 | 09:05 AM
Kevin's Avatar
i think the cable need replacement, anyone know the part number that I need to order ?
Old Aug 29, 2007 | 09:10 AM
dgeesaman's Avatar
Maintenance Monster
http://forums.maxima.org/showthread....ht=brake+cable
matts95max
Apr 23, 2025 10:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
captchaos
Mar 15, 2016 12:18 PM
Maxie40
Sep 14, 2015 11:28 AM
bbsitum
Sep 11, 2015 04:55 PM
