'95 Maxima cranks but doesn't start
Old Aug 23, 2007 | 08:15 AM
Pilot8680's Avatar
My '95 Maxima cranks but doesn't start. What are the common cause of this if there's fuel, battery is good, starter is good? One of the mechanic tapped the ecu while turning the ignition and it started right up. I tried couple of time but it doesn't work so I think its something else.
Old Aug 23, 2007 | 10:03 AM
max ride 41's Avatar
if he tapped the ecu, why did'nt he check the connections, etc.??? make sure everything is plugged in and connected tightly.ie, battery terminals, alternator, clean your maf and air filter and check your plugs.
Old Aug 23, 2007 | 10:09 AM
Linkage23's Avatar
either fuel or spark is the cause...narrow it down to see if he connected the ECU harness correctly and make sure there aren't any wires shorting out ojn the harness....good luck man!
Old Aug 23, 2007 | 12:33 PM
pretty much wat i said.........
Old Aug 23, 2007 | 08:29 PM
urmab's Avatar
hey pm me i might be able to help you
Old Sep 7, 2007 | 09:04 AM
wayne937's Avatar
Don't forget the crank sensors. They provide the spark that you need for the ignition. I believe that there is two but maybe only one is bad.
Old Sep 7, 2007 | 09:48 AM
Nealoc187's Avatar
SLOW
I can almost guarantee the problem is bad grounds to the starter. I just went through this problem over the last couple months and finally actually burned up my starter because I was out of town and the car wouldn't start, I didn't really have a choice but to try to keep cranking it hoping it would catch (it would usually start after like 30 seconds of cranking, but this time it didn't and I killed the starter).
Anyhow, per advice in various threads I added a couple large ground wires, most important was the one directly to the starter bolt, and then attacked the the other end to the chassis ground (under the battery, same place where the wire from the negative battery terminal attaches). Car started u IMMEDIATELY like a brand new car. Started in like 1/4 of a second of cranking, instead of 15, 30, 45 seconds. It's like a new car again. Total cost of the ground wires and terminals from local stereo store = $5 from. Try this before you burn out your starter like I did and have to spend $120 on a new starter, seriously. I'm positive this is your problem.
LilVito
Oct 25, 2019 08:12 AM
kjlouis
Nov 24, 2018 06:09 AM
02PearlSE
Oct 7, 2015 02:12 AM
Jcof88
Aug 3, 2015 10:43 PM
