rear camber adjustment
Old Aug 23, 2007 | 05:26 PM
GriffinW's Avatar
Ill make this as short winded as possible....
My rear beam is bent, causing the camber on my left rear tire to be positive... anybody know how to fix this? Ive heard that I cant adjust rear camber because of the beam...is this true.
Old Aug 23, 2007 | 05:34 PM
pmohr's Avatar
No more Maximas...
Short of bending the beam back into place, camber isn't really adjustable on the A32. I'm sure one could come up with a hack way of doing it (a tapered spacer from where the hub bolts to the rear suspension) but nothing as designed from Nissan.
Old Aug 23, 2007 | 07:02 PM
Fr33way™'s Avatar
Wild for Width
You should be able to get a whole beam for much less than you would pay correcting the problem.
Old Aug 23, 2007 | 07:41 PM
GriffinW's Avatar
how much for the beam you think?
its causing some weird noises, like a vibration that sounds like if i were to have a flat spot on the tire. But only at < 35mph
Old Aug 23, 2007 | 08:58 PM
Fr33way™'s Avatar
Wild for Width
There was a local one going for like $45 so I would imagine you can find one for around $100 or less if you can pick it up. It will be more or less depending on what components (if any) come with it.
Old Aug 23, 2007 | 09:58 PM
maxpeed96plat.'s Avatar
Here you go u got tenn, alabama, etc.....http://car-part.com/cgi-bin/search.cgi
matts95max
Apr 23, 2025 10:44 AM
bbsitum
Sep 11, 2015 04:55 PM
flu2000
Sep 8, 2015 02:23 PM
