If not faulty ECU...what could it be?
Old Aug 26, 2007 | 11:31 AM
97SEdriver's Avatar
this place is dead
So here the short story, had O2 sensor codes, evap codes and an egr code, along with a KS code.
Other threads suggested cleaning the plugged EGR tube, so I cleaned it with TB cleaner, put everything back together.
With normal scan tools from Advance auto, could read codes, but was also getting a PRD12 transmission code even though I have manual. I could not clear the codes with the scanner at Advance. So, I had someone at a shop clear the codes out with his PA state emisions computer. I came back at ~80miles of driving, I got a "not ready" reading. So since then I've driven more than 900 miles, no CEL.
However, I just checked in with the mechanic I had clear the codes, he says the KS code is back, but EVERYTHING else is reading "not ready"....he now tells me I can bring it to another shop spend $150 in parts trying to fix it, then get an inspection waiver.
Anyone have any idea what the hell is going on here? I feel like most of these shops know less than I do, so my last ditch effort might be to bring it to the stealership.....although I really, really don't want to.
Old Aug 27, 2007 | 04:20 AM
97SEdriver's Avatar
this place is dead
bumping for visibility on a Monday morning
Old Aug 27, 2007 | 03:06 PM
95maxrider's Avatar
Lightly modded
Oh man, that's sounds similar to problems I have with my car, except my problems are caused by an engine swap and an ECU out of a 98 Max which conflicts with the 96 I30 EVAP system stuff. Your situation sounds no less complex, and it's very odd that it reads the KS code but says the rest are 'not ready'. I would probably just pay the $150 to get the waiver.....
Old Aug 28, 2007 | 07:45 AM
Cutler's Avatar
Trade it in on an Accord.....They don't break down...
Old Aug 28, 2007 | 08:33 AM
97SEdriver's Avatar
this place is dead
But I have a wife and kids....I don't want to pull a former Gov of NJ on them and turn gay.......
Old Sep 2, 2007 | 12:26 PM
joepino's Avatar
maybe some bad engine grounds. i know that can thow things out of wack. just get some 4 guage wire and throw a couple on there see if it helps. its only a couple busks and it may work
Old Sep 2, 2007 | 01:14 PM
Kevlo911's Avatar
Kevlo for President
So do you have an auto ECU or manual ECU? Was your car converted? Have you checked the TSB for the EGI harness?
Old Nov 4, 2007 | 05:56 PM
97SEdriver's Avatar
this place is dead
Well, now this inhibitor switch code (1101) might make some sense....sort of....because now my reverse lights do not work....
or at least I didn't notice until recently because I had to pull most of the tint off my car.
I think my ECU is somehow messed up though, because I still do not have a check engine light, it's been like 2000 miles, probably more.
my gas mileage is still good and the car runs fine however....despite the O2 sensor codes.
Old Nov 4, 2007 | 06:03 PM
97SEdriver's Avatar
this place is dead
fyi these were ALL the codes I got at the time....
P0150- 0303 (O2 sensor - Bank 2 Sensor 1)
P0325- 0304 (Knock Sensor- Bank 1 or 1 Sensor)
P0440- 0705 (Evap Emission Control system Malfunction (probably gas cap)
P0136- 0707 (O2 sensor Bank 1 Sensor 2)
P0446- 0903 (Evap Control System Vent Circuit Malfunction)
AND...the confusing one.....P0705- 1101 (Trans Range Sensor Circuit Malfunction (PRNDL Input))
Old Sep 21, 2009 | 08:46 AM
yoshiyosh's Avatar
i'm stuck on P0705 too, still searching for help...
Derrick2k2SE
Nov 19, 2015 10:14 PM
tnewbs
Aug 28, 2015 10:15 AM
Shock_and_Awe
Aug 23, 2015 01:02 PM
vman
Jun 23, 2002 12:04 AM
