Tokico or KYB shocks for OEM replacement
Old Sep 1, 2007 | 03:56 PM
0260N9's Avatar
My max is making a clunking noise when i hit bumps. I took it to two different shops to get it inspected. They both said that it could be the struts (passenger side) or the ball joint on the same side. Since the car is 10 yrs old I am going to redo as much of the suspension as I can afford. I already replaced the end links, sway bar bushings and now want to replace the tie rod ends, struts and LCA's. The problem is that I dont know what struts to go with as an OEM replacement. I had tokico stuts and eibach springs on my 3rd gen max and the ride was too stiff for me(it handled great). So this time i am staying with the stock springs and just replacing the struts, mounts & etc. Which struts of the 2 would be the best stock replacement.
Old Sep 1, 2007 | 05:52 PM
RA030726's Avatar
I'm nutty for Nissans
OEM struts are tokico so tokico blues are as close as youll get.
Old Sep 1, 2007 | 06:17 PM
bkmax98's Avatar
tokicos ftw!!!!
0260N9's Avatar
Thanks alot.
vingodine
45
May 21, 2016 12:46 PM
Maxima_Joe
Nov 25, 2015 08:19 AM
95Maxi
35
Sep 2, 2015 10:37 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
